new monster v8 no 4.0 here !!! Start up vid on page 28 :)
ross2009
Post Mon Mar 10, 2014 3:11 pm
done alittle more made the pivot arm for the servo today
lined it up
and welded it
plenty of weld on there don't want that comin lose
mock testing it in the car
Turbo M20
v8 project 6.0 twin turbo
Jamie8GTi
Post Mon Mar 10, 2014 9:00 pm
loving that fabrication mate!
ross2009
Post Mon Mar 10, 2014 9:09 pm
my fav bit making things :)
Turbo M20
Jamie8GTi
Post Mon Mar 10, 2014 11:27 pm
that intake you made for your m20 turbo was a piece of art!!
ross2009
Post Tue Mar 11, 2014 6:05 am
Jamie8GTi wrote:that intake you made for your m20 turbo was a piece of art!!
thanks dude :)
Turbo M20
ross2009
Post Sat Mar 15, 2014 10:05 pm
Turbo M20
Post Sat Mar 15, 2014 10:23 pm
I trust you're going to relieve that sharp sticky-out length of steel that could gouge a passenger's leg? :wink:
ross2009
Post Sat Mar 15, 2014 10:38 pm
ha yeah not 100% finished yet ive left it long so i know where to put the glovebox back in, didnt want to cut it short then be in the shit
im waiting on material to finish it off but with out that cant really do much more
Turbo M20
Post Sat Mar 15, 2014 11:15 pm
Fair enough, fella - play on! :wink:
Jamie8GTi
Post Sun Mar 16, 2014 11:28 am
This has gotta be my favourite build on here! as well as being an insane engine its got some great thought and hard work in it! can't wait to here this thing growl!
ross2009
Post Sun Mar 16, 2014 2:45 pm
thanks dude I do try :)
as I was doing the servo bracket found another little hole behind the fuse box so now I know why I was always getting a wet footwell
and now all done
Turbo M20
ross2009
Post Sun Mar 16, 2014 7:58 pm
ive also got the clutch on order hes going to get bk to me this coming week and dimentions and price
but he recommended a twin plate organic which will still keep a nice pedal feel yet hold up to about 6-700 ft lbs or torque im expecting this to be quite pricey
Turbo M20
Jamie8GTi
Post Sun Mar 16, 2014 8:29 pm
I'm glad most things for my build are off the shelf parts :D
ross2009
Post Sun Mar 16, 2014 8:34 pm
lol this clutch is completely custom one off jobby lol
Turbo M20
ross2009
Post Mon Mar 17, 2014 3:01 pm
as I can't do much more with the brake servo side as I'm still waiting for parts I decided to start on the engine bay tidy it up a little so I started on the bulk head blower cover thingy basically just stripped the sound deadening off it as it's going to be all painted
Turbo M20
Phill172
Post Mon Mar 17, 2014 5:05 pm
you modifying or selling those driftshafts :D
ross2009
Post Mon Mar 17, 2014 5:26 pm
ha I'm keeping them phil I need to get them modified the end flanges need to be cut of and new bigger ones put on as my diff is obviously bigger and they need shortening by about 20-30 mm too
quite nice ain't they winkeye
Turbo M20
appletree
Post Mon Mar 17, 2014 9:34 pm
Did you sort the trailing arm to filler pipe issue? How? :D
ross2009
Post Mon Mar 17, 2014 9:38 pm
appletree wrote:Did you sort the trailing arm to filler pipe issue? How? :D
erm not to sure yet as altho its got all the trailing arms bk on the car isnt bk on the ground yet but i did have a little look and what ive done is turned the hose around so the hump is up in the air
not sure if it will work or not was just playing around what i might do is make a hard line to the tank and just use a very small rubber coupling on the tank inlet
ill toy around with that when i get round to it :)
Turbo M20
appletree
Post Mon Mar 17, 2014 11:01 pm
So you think there is a reasonably easy solution then? I haven't looked at mine yet but was thinking about cutting it off but if you sort it I 'll try and keep them on. :D
ross2009
Post Tue Mar 18, 2014 2:03 pm
I'll come up with some solution mate don't you worry
any who these turned up today new brake reservoirs for the master :)
Turbo M20
ross2009
Post Thu Mar 20, 2014 8:27 pm
so my master cylinder finally turned up today after 2 weeks of waiting
its from a vw sharan 1'' bore which should work well with my 4 pots and is quite stumpy too
as my feeds from the reservoirs are femal threads ive had to slight adapt them i got these which are from a 1960s beetle
then these to adapt the female part to the plastic bits
which will then look some thing like this
just have to plumb it all in and thats then the brakes all sorted just in the process of refitting the glovebox bk in too as it wont fit properly in front of the servo now so ive had to remake a new hinge system and relocate it
another job ticked of the list
Turbo M20
manse73
Post Thu Mar 20, 2014 9:02 pm
Box ticked job done love it
bruv chariots rule
manse73
Post Sat Mar 22, 2014 5:34 pm
UPDATES :D
bruv chariots rule
ross2009
Post Sat Mar 22, 2014 5:50 pm
not touched it mate as I'm working on my van at the mo I've managed to do the hinge for the glove box I've had to cut the glove box shorter as it wouldn't go bk in as it was,it's all done so just gotta take it all out paint it all and fit it all properly
couple of quick pics of the glove box
Turbo M20
ross2009
Post Sun Mar 23, 2014 6:42 pm
just a couple more of the shortened glove box and new hinge
Turbo M20
ross2009
Post Sun Mar 30, 2014 9:12 pm
progress has been slow as of late and ive been working all weekend but i have done a few little bit got the new front brake lines and adaptors for the master as they where m12s not the bmw m10s and finished of fitting the glove box
looks a little tight dont it
adaptors and new bmw hard lines
Turbo M20
manse73
Post Mon Mar 31, 2014 12:10 pm
Very neat good work Ross will call in next time I'm up your way
bruv chariots rule
ross2009
Post Mon Mar 31, 2014 12:22 pm
yeah mate I'm at the stage now where it's just buying lots of bits now
welcome anytime mate
Turbo M20
ross2009
Post Wed Apr 02, 2014 3:02 pm
finally took the drive shafts down to get them altered for the new diff so will be getting a phone call and prices shortly
the alternator bracket turned up from the states today too
should looks like this when its all together
you can prob tell what this engine is gonna be like when finished :)
Turbo M20
Quaser
Post Wed Apr 02, 2014 3:48 pm
so is the sharan m/c a direct fit to the servo? maybe cheaper alternative to the 750il m/c
ross2009
Post Wed Apr 02, 2014 4:32 pm
to a Clio servo yes near enough not 100% sure on the e30 servo mind
the only thing needed is the tube that the adjustable rod goes up needs chopping down a little so it doesn't bottom out in the servo but then that leaves a gap so a 2mm spacer is needed between the master and servo I'm yet to make that
only other thing is mine outputs on the master are m12 were as bmw is m10
Turbo M20
ross2009
Post Fri Apr 04, 2014 9:52 pm
got a phone call today on modifying my drive shafts 4-500 pound EACH !!!!!! dont think so my friend so im gonna buy a couple of bits and machine them my self i aint paying that for some i can do
any whoo picked up my full gasket set up today too so altho its gone abit slow at the mo bits are still turning up,
got some more goodies coming from the states too so they should be here beginning of next week pics to follow
gasket set
big bore
Turbo M20
DanTheMannn
Post Tue Apr 08, 2014 3:06 pm
looks absolutely unreal! Can't wait to see it finished!
ross2009
Post Tue Apr 08, 2014 8:14 pm
DanTheMannn wrote:looks absolutely unreal! Can't wait to see it finished!
neither can i mate :wink:
Turbo M20
