lollipops offset or standard?
broadie
Tue Feb 25, 2014 7:48 pm
Will be change the lollipops soon its on a stock touring.Daily drive not a track weapon. Should I fit standard or offset? I read that the offset make it turn in better but is their any down side to the offset one's?
Thanks Broadie
rich318i
Tue Feb 25, 2014 9:23 pm
E36 ones fit the E30 ?
Tue Feb 25, 2014 9:25 pm
rich318i wrote:E36 ones fit the E30 ?
Common knowledge.
rich318i
Tue Feb 25, 2014 9:28 pm
Sweet
broadie
Wed Feb 26, 2014 3:27 am
Thankyou Dan
tha881
Wed Feb 26, 2014 8:26 am
Is there any real difference between the e36 m3 and e30 m3 ones? I was going to get the e30 ones
http://www.ebay.co.uk/itm/BMW-E30-M3-FR ... 453wt_1004
harry_p
Wed Feb 26, 2014 12:11 pm
E30 and 36 ones are interchangeable, including the metal brackets.
More e36s got offset bushes though, both 3.0 m3 and 328i sport got eccentrics.
Be careful if they're listed as e36 m3 though, because the 3.2 had normal centred bushes, but with more rubber than the standard centred e30 / e36 bush.
cheers,
harry
steve_k
Sun Mar 09, 2014 9:21 pm
Will be buying a set of these in a few weeks, & getting new brackets at the same time,
Only problem is that at the moment I've got normal poly one's on the car, is it possible to use a two leg bearing puller to remove the old brackets from the wish bone??
If not is there any other way to get them off?? Angle grinder??
broadie
Sun Mar 09, 2014 11:37 pm
Spanner and hammer.
leeparkes
Sun Mar 09, 2014 11:46 pm
steve_k wrote:Will be buying a set of these in a few weeks, & getting new brackets at the same time,
Poly ones are normally easy to get off, undo the lollipops off the rail and twist them off.
rob0r
Mon Mar 10, 2014 11:51 am
Thanks for the link Dan, just bought them, nice and cheap!
G-Bear
Mon Mar 10, 2014 11:35 pm
steve_k wrote:is it possible to use a two leg bearing puller to remove the old brackets from the wish bone??
I used a bearing puller to get my old bushes off the wishbones.
steve_k
Thu Mar 13, 2014 10:02 pm
Easy? Or hard? Never used on before :o:
maxfield
Thu Mar 13, 2014 10:08 pm
Steve it you take the arm completely off I've got a press
rich318i
Thu Mar 13, 2014 10:09 pm
Emailed C3BMW and they said use the E30 bushes and dont use the E36 ones
steve_k
Thu Mar 13, 2014 10:17 pm
rich318i wrote:Emailed C3BMW and they said use the E30 bushes and dont use the E36 ones
Any idea why not??
Also, Jamie cheers for that dude won't be till the end of the month kinda time,
OP sorry for the thread hijack :o:
maxfield
Thu Mar 13, 2014 10:27 pm
No worries. Just let me know :wink:
steve_k
Thu Mar 13, 2014 10:28 pm
maxfield wrote:No worries. Just let me know :wink:
steve_k
Thu Mar 13, 2014 10:30 pm
Well they appear to be the same & you would have thought they would be stronger on account of the e36 being heavier, well that's how it looks to me lol
broadie
Thu Mar 13, 2014 11:30 pm
Yes but the E30 was well made winkeye
rich318i
Fri Mar 14, 2014 8:47 pm
They said the E36 ones are 1mm smaller than the E30 ones and not advised to be used, only at your own risk!!!
maxfield
Fri Mar 14, 2014 8:54 pm
The E36 is also very well made!!
rich318i
Fri Mar 14, 2014 8:58 pm
both are well made but there is 1mm between them too^
maxfield
Fri Mar 14, 2014 9:15 pm
According to C3...
But there are a lot of people that will disagree with them...
rich318i
Fri Mar 14, 2014 9:20 pm
maxfield wrote:According to C3...
you would get away with using them on road but not if you do track days. I believe they pop out like the powerflex ones can do
Fri Mar 14, 2014 9:24 pm
Does that mean they will drop out the car then? :mad:
Fri Mar 14, 2014 9:25 pm
Your chatting shite again rich,,,, :roll:
rich318i
Fri Mar 14, 2014 9:27 pm
well his used them poly ones on his M3 on trackdays and they popped out so im not chatting shit just going by what they told me. I believe them they been in the game a few years and all the advice they have given to others on here has been spot on
Fri Mar 14, 2014 9:38 pm
What has any of this got to do with 'them poly ones' ??
rich318i
Fri Mar 14, 2014 9:52 pm
guessing thats why they say use the E30 one and not the E36 ones if you do track days
Fri Mar 14, 2014 10:36 pm
You best buy some E30 ones then, especially as your car will be the next best thing to an F1 car built for the road
steve_k
Fri Mar 14, 2014 10:38 pm
Rich318i, according to bmw fans.info the e36 m3 3l offset bushes & brackets can be used on the e30 chassis,
So what does that tell you???
Fri Mar 14, 2014 10:49 pm
steve_k wrote:Rich318i, according to bmw fans.info the e36 m3 3l offset bushes & brackets can be used on the e30 chassis,
Its a conspiracy?
steve_k
Fri Mar 14, 2014 11:02 pm
Its a conspiracy?
& that rich is being taken for a ride (on the short bus)?
