can your get an iron exhaust manifold planed?
xavier
Can you get an iron exhaust manifold planed to true up the surface that comes in contact with the head?
Yes, a pretty straightforward task for a machine shop.
- **BANNED**
I would not attempt to plane one,I would be asking for the thing to be 'surface ground flat',myself!
Youth is wasted on the young.
gareth
No need at all malc, a fly cutter will do the job just fine, as it does on cylinder head faces.
Surface grinding a manifold is overkill of the highest order!
xavier
what is the difference between the two?
- **BANNED**
I have'nt a clue!
My answer is based on dealing with a warped manifold about 20 years ago,when I was running an E28 520i that pulled three studs out.
I'm happy to plane timber,but my plane does not go near metal,it makes an 'orrible mess of the blade.
Having a branch of the family heavily into all things CNC, I can answer this one. Fly cutter is a blade similar to that which would be held static against the rotating workpiece in a lathe, but is mounted on a rotating wheel instead. With the workpiece moved against the rotating cutter, it will just cut a circular groove in the surface, but if either the cutting wheel or the workpiece is moved around, the whole surface will be ground flat.
A surface grinder is similar in principle, but substitutes a (usually) cup shaped grinding wheel for the fly cutter.
Check out this badboy!
Specially made for an M30 cast manifold?
yes you can - had mine done by the machine shop who sorted the head test/skim/rebuild out - they said its a bit of a pig to do but its doable.
Dave_M3
Clamping the manifolds is awkward but other than that, it's a very basic task and it's the same as skimming a head or block.
I skimmed the cast exhaust manifold on my TD5 Defender twice as they kept warping and snapping studs. Fitted an aftermarket one then though and had no more issues
Machined an M42 manifold that a friend warped when he got it welded too and was perfect afterwards.
davethegoat
It doesn't help the OP much, but I've used these guys for cylinder heads. A manifold would be a piece of wee I'm sure. http://www.precision-lapping.co.uk/ Pity manifolds are heavy and expensive to post!
