M52 b30 stroker rebuild back on the road
Post Tue Dec 10, 2013 7:49 pm
Nice diff ! :)
alpina123
Post Tue Dec 10, 2013 8:06 pm
Very nice
Cypriotgeeza
Post Tue Dec 10, 2013 11:02 pm
got to love a bit of rear end action winkeye lol
Check my M30 build threads:
Post Wed Dec 18, 2013 4:21 pm
the springs are back from powder coating and the rear adjustable arb fitted .
looking a bit flaky
as you were 8)
i could've had them any colour i liked but went for black to avoid a council fest underside .
rear arb fitted and some council spec rear springzz chucked on for a stop gap till i get some more tinker time
leeparkes
Post Wed Dec 18, 2013 6:50 pm
It will feel a tad livelier with that diff ratio and torsen to boot! :cool:
Post Wed Dec 18, 2013 11:09 pm
it's gonna be like a whole new ride with all the changes :D
SteSE
Heading for the Naughty Room
Post Fri Dec 20, 2013 2:35 pm
Nice drive train setup
87.5 Impact FM
PS3: gary_bunter
1986 325i resto - M52'd
C plates are fastest
AndyZippy
Post Fri Dec 20, 2013 7:16 pm
Mick, what (if anything) did you need to change with the gear linkage and gearbox mount to change to this from the iS 'box?
Post Sat Dec 21, 2013 12:47 am
i've not asked Yoda yet but i'm banking on the 320i linkages i have and same mountings/bracket from the 318is ...i might look into gearbox rubber mount upgrade but never had a problem with the oem ones ....yet .
craigieeb
Post Sat Dec 21, 2013 1:40 am
Use the linkage that came with the 2.8 box,
Dont know if there is a difference between the m40/m20 box mount bracket, but I used the m20 with no problems.
appletree
Post Sat Dec 21, 2013 12:28 pm
What diff was on the car before the 3.07?
Post Sat Dec 21, 2013 1:00 pm
3.64 slipper
Post Sun Dec 22, 2013 12:33 pm
the postman has just been ...on a Sunday 8O with my order from BMW .
i thought these dust covers were meant to be blue :?
Post Sun Dec 22, 2013 7:13 pm
Not from BMW Mick, Bilstein provide blue
Post Fri Mar 07, 2014 10:43 pm
i took the cover off the car the other day and fitted the diff along with the shiny rear springs as the mot is due on the 14th of this month and i'd like the garden ornament mobile again ...thank fook the winter is nearly over and my car never floated away or drowned,living on the top of mount consett has a plus side i guess :D
I love this jack .
i still need to fit the front springs/dampers,ARB and these mondeo rear drop links that can be used as a straight replacement for e30 front droplinks ...the mondeo ones are rose jointed so can only be an upgrade/improvement over bmw stock parts .
ECP part number on the box ,i think they cost around £30
after fitting the diff i got the jump leads out and fired the bitch right up ....time to see if it will diff ... would berude not to innit :twisted:
with it being a z3 3.07 torsen married to a 318is box i did wonder if it would pull away in 1st gear but it managed and with a dip of the clutch i'm side ways on the first attempt !
so i tried a burn quick burn out and needed a boot full and some clutch pedal action but it span up and left some 11's so i'm happy and the diff test went well :twisted:
in e30 terms what ratio diff would be the same ? i'm guessing my top end is gonna be quite fast ?
rich318i
Post Fri Mar 07, 2014 10:48 pm
magpie wrote:the postman has just been ...on a Sunday 8O with my order from BMW .
Billy ones are plastic crap. Is it that time of year everyone are doing their shocks. 15 quid for them boots the rip offs
Post Fri Mar 07, 2014 11:05 pm
£15 each boot rich,but they came in a nice BMW bag :mrgreen:
rich318i
Post Fri Mar 07, 2014 11:14 pm
Snap!!! :D the rip offs
The tits gave me the wrong nuts for the billy tops gave me course nuts and not fine. Total different car now!! with the B8's and H&R set up, brakes are better with the standard brakes, off set bushes next then the Eibach ARB
What spring pads you using fella?
Post Fri Mar 07, 2014 11:54 pm
i'm using the thinner rear pads [yes they have two sizes] i think maybe even m-tech ones if such a thing exists :?
i'm looking forward to fitting the front suspension but will probably do it after the mot ,then pay the rent on 1st of next month .
i need to change the h/brake , the ratchet has gave up ratcheting and the drivers side h/brake shoes need some adjustment and then i need to fit these .
and that should be a straight pass or i'm having an argument !
rich318i
Post Fri Mar 07, 2014 11:58 pm
DanThe wrote:Not from BMW Mick, Bilstein provide blue
Blue to look fancy Dan and they are sh---
rich318i
Post Sat Mar 08, 2014 12:02 am
magpie wrote:i'm using the thinner rear pads [yes they have two sizes] i think maybe even m-tech ones if such a thing exists :?
did the 9mm front on mine but with the new off set bushes guessing will be a 3mm -
rich318i
Post Sat Mar 08, 2014 12:08 am
no way think be sweet
what rims you using?
Post Sat Mar 08, 2014 12:09 am
magpie wrote:in e30 terms what ratio diff would be the same ?
3.07/0.81 = 3.79
Post Sat Mar 08, 2014 12:20 am
3.07/0.81 = 3.79
oh that's not bad at all,pulling the engine and fitting the e36 box can wait a bit longer :D
or at least until i drive it regularly again and find out if both the old diff and the 318is box were making a racket .
either way the next time time i pull the engine,the e36 box is getting cable tied in ....it will be used at some point on my watch :( :D
rich318i
Post Sat Mar 08, 2014 12:25 am
magpie wrote:
3.07/0.81 = 3.79
Try and get a 3.25:1 with the e36 box
rich318i wrote:no way think be sweet
eerm ....
these :mad:
rich318i
Post Sat Mar 08, 2014 12:28 am
your sorted then now !!! with the 16's
Morat
Post Mon Mar 10, 2014 6:23 pm
magpie wrote:
bss325i wrote:You can get new dust boots for the front shocks from BMW.
31321128548
Where on earth does Morat live?
The state of those springs! 8O
cheers Barry i was going to ask about them in BMW chat as i can't find them on the billie stein website .
i'm going to have the springs powder coated along with the rears when the car gets sorned end of next month ,this year gets an extension into the autumn after the shit start to the season i had .
Morat is from out in the sticks of Yorkshire dales way so the springs have been covered in horses shite all there lives,he's now running an lpg powered Jeep as the shite is getting deeper lol
Haha the Jeep is prehistoric but strong. And rust free underneath which is my new criteria for judging vehicles!
All is not lost... Bilstein do shocks for a Jeeps too :)
It's good to see those parts live on. I loved driving FUCR but the rust was in nasty places like the base of the B pillars and I couldn't flog it on to some unsuspecting victim who'd probably snap it in half one day.
It turned out that FUCR had a blow over below the glass before it was served to me so it looked fine on the bay but was only going to be a short term fling. I decided to put the parts on and enjoy it while it lasted and got 5 years out of it.
Cheap motoring compared with my old Fiat Coupe 16v turbo which snapped its cambelt. .....
tom325ise
Post Wed Mar 12, 2014 12:26 am
Morat wrote:
31321128548
I bought the cylinder head from your FUCR off Mick a few months back. It's going to be flatted off next week then will be going onto my car in about 6 weeks time (after my house extension is finished). I'll then be a few plastic trims short of a completed project!
leeparkes
Post Wed Mar 12, 2014 12:42 am
Nice progress Mick :cool:
rich318i
Post Wed Mar 12, 2014 1:04 am
what springs and billies you using?
Post Wed Mar 12, 2014 4:42 pm
rich318i
http://www.larkspeed.com/index.pl?a=i&p ... ension-Kit
tom325ise ,good to hear you'll be back on the road soon .
Cheers Mr Parkes
Post Sat Mar 22, 2014 10:17 pm
found out cause of a breaking squeak ...too many burn outs !
found a new set of rear pads down the shed that were in the boot of a 323i rot box i broke a while ago
new boots fitted....i hate that mudflap mark !
that's the weighbridge dodged for another year
no advisories which is nice ..nine days to go until i pay the rent :(
while taking it to the mot station i've noticed a random howl from somewhere...i hope to fook it's not the new Diff !
rich318i
Post Thu Mar 27, 2014 11:01 pm
magpie wrote:rich318i
Cheers Mr Parkes
using same dampers B8's but using the H&R springs and Eibach ARB
Brake wise going the EBC and see how they go
craigieeb
Post Thu Mar 27, 2014 11:34 pm
You found out what it is yet fella?
