E30 320i Starting & Idle Issue
Altrezia
Post Wed Mar 05, 2014 3:37 pm
Hey guys,
My 320 is getting harder and harder to start lately - and it hunts a lot when idling. It's a stock engine (pretty much).
Here's a video - last time I started it was yesterday at 5pm. The longer I leave it the harder it is to start.
I have a fuel filter and new spark plugs to go in, but I'm guessing this may be a FPR or pump issue?
Any ideas would be awesome.
Thanks again!
[youtube][/youtube]
Grrrmachine
E30 Zone Wiki / Team Member
Post Wed Mar 05, 2014 3:45 pm
Air leak, worn injectors, or fouled up spark plugs. I've never heard of a failed FPR, and a failed fuel pump will stop the car starting completely, not just "harder" to start.
Check here:
http://www.e30zone.net/e30zonewiki/inde ... oubleshoot
Altrezia
Post Wed Mar 05, 2014 4:08 pm
Cool. Thanks :)
Post Wed Mar 05, 2014 4:20 pm
Try disconnecting the battery or ECU for an hour or so to reset it, then let it idle for at least 10 minutes, switch off, then take it for a drive throughout the rev range.
Altrezia
Post Wed Mar 05, 2014 6:17 pm
Actually, the batter does get cut all the time - it's a race car and the cut-off switch is used every time it's parked up.
Post Wed Mar 05, 2014 6:26 pm
Well, that may explain your hunting idle - you need to give it 10 minutes of idle time to enable base idle settings to be learnt.
Altrezia
Post Wed Mar 05, 2014 6:38 pm
Thanks - that makes sense.
Post Wed Mar 05, 2014 6:57 pm
Connect a 47 ohm, 3W resistor across your battery isolator switch.
