exhaust help
Mrmyke00
Post Wed Mar 05, 2014 5:21 pm
Hi guys
Bit of help needed , will an exhaust off an e30 325i cab fit an e30 325i touring 1990
Downpipe looks the same
Cheers Mike
pac1982
Post Wed Mar 05, 2014 5:32 pm
i just found out recently that yes they do, all E30's with a 325 engine will share the same exhaust, where you may find some slight differences is in the brackets like i did but this was easily over come.
I think the bracket difference came about due to auto/manual difference but the exhaust system itself will be the same on every 325 unless custom
1990 BMW E30 318IS (Sold)
1990 BMW E30 316i (RIP)
Mrmyke00
Post Wed Mar 05, 2014 6:29 pm
Excellent thank you
Post Wed Mar 05, 2014 7:52 pm
Depends if its a 2 piece or 3 piece system
The manifold for the 2 piece is different to the 3 piece - body type doesnt matter - saloon, touring or convertibe all use the same bits but you cant fit a 3 piece system to a manifold that had a 2 piece attached from the factory and vice versa
