The car was in excellent condition for it's age. Only one previous owner who was in his sixties. The car was kept in garage in all of it's life, although there were some typical underbody rust as I later discovered, but I'll show you later.
Car ran an indicated 258000km's (about 160k miles) but the instrument cluster had been swapped before to have a tachometer instead of a big clock.
Real mileage was about 320000km's (about 200k miles) as I figured out from the original service book which I got with the car.
Car had very good service history, even all the oil changes were made in the BMW Schneider service/showroom. Just in the previous 2-3 years the first owner changed all the suspension bushes, anti roll bar bushes, heater motor, water radiator, fanbelts, thermostat, heater motor switch (which is common e30 fault, when you notice that the 1. and 2. state of the heater/blower motor is not working, it's only the fault of this small part, cost about 15pounds to change for a new original part and it will work again for 20years!) new summer and winter floor mats, new winter tires (sadly not the correct size, which has to be 195/65/14 and it was 185/60/14 instead, so speedo was a bit optimistic). I also got 12(!) pieces of original 14" wheels with the car, 8 of them alloys freshly refurbished.
Car NEVER had an accident before, most of the bodywork was originally painted in 1986, except for the wings, the rear fender and the side covers.
Sadly the outer covers were replaced for aftermarket "Klokkerholm" parts which I don't recommend, they are much thinner as the original BMW parts, and it showed after lifting the car up several times, You can see from the reflection of the paint
that it became curvy
Use only original BMW parts no aftermarket bullshit! This is for everyone!
Some pictures from just days later the purchase:
