I spent the weekend fitting an OBC and cruise control to my 1990 325i cabriolet.
It all seems to be working but the brake check warning light does not go off when I apply the brakes.
The brake lights are working and the cruise disengages when I brake.
I have tried unplugging the cruise control's brake connection to the accessory socket but it has no effect on the warning light.
Any ideas, please?
Ben
Brake check light
- **BANNED**
Are the brake lights working?
Youth is wasted on the young.
BenHar
daimlerman wrote:Are the brake lights working?
BenBenHar wrote: The brake lights are working and the cruise disengages when I brake.
BenHar
Brian, Have you got any suggestions?
Ben
Ben
I doubt if it's anything to do with the cruise control fitting.
Check that both brake lights are of equal brightness, and if possible, get someone to follow you while you drive to see if the brake lights do exactly what they should.
- **BANNED**
Brianmoooore wrote:I doubt if it's anything to do with the cruise control fitting.
BenHar
Will do, Brian, thanks.Brianmoooore wrote:I doubt if it's anything to do with the cruise control fitting.
The cruise control introduces a couple of extra switches/paths to the brake light circuit which made me suspect that. I'll check the lights and clean all the contacts.
Thanks for your input, too, Malc.
Ben
BenHar
Fixed this today.
Above the glove box there is a loom connector with two wires, a large red/yellow and a small black/green. The black/green was cut (black/green is the feed from the overhead check pabel to the rear lights check relay at the rear).
I must have cut the wire somehow when refitting all the trim panels.
Ben
Ben
