Ah that make sense, I had a quick go last night on trying to remove these, but left them to try another day. I can only get an open spanner to these rather than a ring spanner so it is slipping off with the amount of force required to loosen these. Any tips? Tried using another ring spanner on the end of the first spanner to get a longer lever. wd40 & shocking with a hammer.Brianmoooore wrote:You've undone the wrong three bolts at the front. Remove the other three and the prop. will come off when you drop the centre bearing.
The large cylinder thing is a vibration damper that's not required with any guibo that's in use today, so can be left off when refitting.
Note the arrows on the outer edge of the guibo, pointing towards the flange in each case.
In the centre section? If so I haven't made any adjustments to this as I wanted to make sure I hadn't missed something at the guibo end, i.e taking out the correct bolts.clarko74 wrote:Have you shortened the prop as much as possible by undoing the big nut and sliding it into itself? This might give you sufficient room to get the bolts out.
You know when looking/stuck one something so long you miss the obvious things.Brianmoooore wrote:Get a socket on the head of the bolts, and just use the OE spanner to stop the nut turning.
