E30 325 (1989) heater issue
sitalchauhan
Post Sun Mar 02, 2014 5:46 pm
Hi. Need some help for my e30 325i (1989). I have noticed that over the last few months I have to turn the heater switch almost to max to get some decent heat. On half way or even 3/4 it's not that warm at all. Can someone help as to what's going on so I can sort out. Thanks
andreia
Post Sun Mar 02, 2014 5:55 pm
Are your pipes goin to the heater matrix hot when the engine is up to temp?
sweep
Post Sun Mar 02, 2014 5:56 pm
Could be that the thermostat is stuck open.
sitalchauhan
Post Tue Mar 04, 2014 8:19 pm
Thanks for the replies so far. Will check the pipes. I am assuming that I will have to take thermostat out to check? Might as well replace it if I do that.
