Removing a broken screw from CPS mount
MrWhite
Tue Feb 25, 2014 11:20 am
I have a slight problem with my M52 engine - the screw securing the crank position sensor (item 10) has lost its head during a previous attempt to remove it and the rest is still in the timing case.
Access from above to drill the remains of the screw out is very limited. What is involved in removing the timing case? Does the head need to come off first? Any other ideas for how to remove the broken screw would be appreciated.
rust never sleeps
MrWhite
Thu Feb 27, 2014 8:07 am
Another clue:
This must've happened to somebody.
rust never sleeps
heathy325
Thu Feb 27, 2014 8:16 am
If the heads snapped off then pull the sensor out and if there's enough stud sticking out then get it got with a blowtorch and use mole grips failing that it will have to be drilled and carefully re tapped
MrWhite
Thu Feb 27, 2014 9:31 am
Thanks for the reply. There is my problem - the screw head has broken flush so mole grips are out. Hand drill is too big to get the bit in line with the hole. I think I'll need to have a go with the Dremmel. I want to avoid taking the timing cover off if I can.
I've not stood and looked at the engine for a while. Can anybody say if the timing case cover can be removed without having to disturb the head or the timing gear?
rust never sleeps
heathy325
Thu Feb 27, 2014 9:47 am
If memory serves me right it's a pig to get the cover off there are a couple if retaining bolts under the rocker cover but don't think the head has I be removed, you can get angle drills that are verry slim I bet that would do the job
Neilios
Thu Feb 27, 2014 3:11 pm
weld a nut onto what you can see and it might turn out with some warming of the case.
MrWhite
Fri Feb 28, 2014 12:25 pm
Thanks for the replies. I'll have a better look at it this weekend.
rust never sleeps
Fri Feb 28, 2014 2:20 pm
Cable ties have their uses, and this might be one of them!
MrWhite
Fri Feb 28, 2014 3:24 pm
Brianmoooore wrote:Cable ties have their uses, and this might be one of them!
To secure the sensor in place or to assist in the removal of the broken screw?
rust never sleeps
Fri Feb 28, 2014 6:44 pm
To keep the sensor in place. No one will know, except you (and the entire Zone.)
MrWhite
Sat Mar 01, 2014 4:12 pm
I don't think I'd be able to sleep at night! I'm surprised that such a suggestion came from you, Brian.
Surely a cable tie wouldn't really work without first drilling a hole in the mount, where the screw goes?
rust never sleeps
