You can buy them individually complete with bracket or as a bush set on its own as per E30 M3 eccentric bushes.
On realoem, it lists the Z4M eccentric bush as 66mm Diameter and it lists the same 66mm diameter for a standard E46 bush so in theory the eccentric Z4M bushes should just press into a standard E46 lolly pop bracket.
Left bracket and bush 31107836862 £56.88
Right bracket and bush 31107836863 £56.88
Bush set 31107838575 £40.63,
Cheaper than a set of genuine BMW, Lemforder and Melyle standard bushes with brackets!
