i have new ones , and lolypops too just need to change over anything special i need to know or is it one in and one out.
cheers
front lower arms
gaszman
- E30 Zone Meets/Events Team
It's important that the lubricant that you use to slide the control arm bushes onto their pins is of a type that is non permanent, such as a 50/50 mix of washing up liquid and water, and that the bush is turned on the pin to its position at normal ride height before the lubricant dries.
Steering alignment (toe) should be checked afterwards.
gaszman
OK CHEERS BRIAN
timmzey
Edited for privacy
gaszman
mondeo they fit
Rear ARB links from an estate around 2000 year.gaszman wrote:mondeo they fit
Cost about the same as E30 ones, give no performance gain whatsoever, but should last considerably longer.
G-Bear
http://www.carparts4less.co.uk/cp4l/c/F ... 414&000016Brianmoooore wrote:Rear ARB links from an estate around 2000 year.gaszman wrote:mondeo they fit
