raising the subframe and prop shaft angle
mattxr2
Post Sun Jan 05, 2014 7:51 pm
has anyone on here have experience in raising the subframe and raising the rear diff mount instead of spacing it down.
iv raised the subframe 15mm and the diff mount the same, afterwards read threads on propshaft angles being out and spacing the diff
anyone on here moved the diff instead or any advise,
ross_jsy
Post Sun Jan 05, 2014 8:43 pm
I know Martin has, think it's in this thread:
http://www.e30zone.net/modules.php?name ... c&t=205156
Demlotcrew
Post Sun Jan 05, 2014 9:19 pm
There is no need to space the differential down, in fact you want it as high as possible!
mattxr2
Post Sun Jan 05, 2014 9:38 pm
yeah iv been looking at the above thread, all the searches iv come across they space the diff down so the subframe is raised and the diff is at its stock location/height
Demlotcrew
Post Sun Jan 05, 2014 9:55 pm
Lowering the differential raises the RC (Roll centre) of the car, which you don't want to do!
Willeh
Post Mon Feb 17, 2014 6:54 am
How does diff position affect the roll centre?
