Quite bad steering wheel shake under breaking.
Stevieabz
Post Sat Feb 15, 2014 5:27 pm
Depending on how hard I break will depend on how hard and fast the steering wheel shakes. Haven't had the car long but don't remember it being this bad when I first got it. I did change the spring on her not long ago, that might be a causal factor? Any help is appreciated.
maxfield
Post Sat Feb 15, 2014 5:28 pm
Sounds to me like a warped brake disc.
Stevieabz
Post Sat Feb 15, 2014 5:31 pm
take the wheel off and check the front disc? Can they be 'unwarped'?
maxfield
Post Sat Feb 15, 2014 5:34 pm
I'd start by jacking it up, spinning the wheels make sure something's nothing is seized cause it to warp.
There's no real way of telling if a disc is warped unless you have a dti gauge handy.
You can't unwrap discs, would require new ones.
Stevieabz
Post Sat Feb 15, 2014 5:41 pm
Yeah I think its time for new disc anyway the cars done nearly 150k on the originals. Thanks for the advise, I'll take a look tomorrow.
chh137
Post Sat Feb 15, 2014 5:45 pm
New disc's and pads.Plus make sure caliper pistons and slides are not seized and working correctly.
manse73
Post Sat Feb 15, 2014 6:06 pm
check ball joints and track rod ends for play whilst it is jacked uo
Sebring grey motorsport convertible
pianist
Post Sat Feb 15, 2014 6:12 pm
manse73 wrote:check ball joints and track rod ends for play whilst it is jacked uo
and lollypop bushes ;)
Post Sat Feb 15, 2014 6:33 pm
pianist wrote:
Major cause of shaking under braking.
Post Sat Feb 15, 2014 6:36 pm
Check the wheelnuts are tight as a first step. :wink:
Stevieabz
Post Sun Feb 16, 2014 3:16 pm
Wheel nuts were not tight enough! 8O Simple as that, thanks guys!
Post Sun Feb 16, 2014 10:05 pm
Good to hear that, dude. Always pays to check the basics first.
Post Mon Feb 17, 2014 10:13 am
Check the seating area for the bolts of the wheel(s) in question. They could well be scrap.
