E30 rear brake upgrade
Trickye30
Post Fri Feb 14, 2014 8:58 pm
Hi does anybody know if you can use z1 280 mm rear discs and e36 rear callipers on a 4stud e30 ? I know the calliper is the same as the one used on the z1 with the 280 mm discs it is just the carriers ????
