Basically I have a D reg Mala green 320i (see new members post a few days ago). I want to keep it stock standard bar the set of lenso bsx 15" i bought and the ride height of course, the arch gap makes me sad.
However, im confused. ...
Ive tried measuring the struts themselves but it appears i need to measure the diameter IN the strut cup (where the spring sits?) - well there is a piece of foam or something that is around the strut at the moment and I cannot move it for love nor money. See Pics below.
So obviously, the answer is to get the wheel off and have a proper look but before I do so, im hoping someone might be able to give me a better idea of
a) what that foam cover thing is?
b) how to remove it
c) whether i should remove it(!) and
d) what diameter my struts might be!
The main strut attached to the hub appears to be 51mm diameter...see below....
but presumably on some models the strut above the cup fits inside this main strut that meets the hub?
My friend has used e36 compact adjustable suspension and his original shocks, but presumably i need to be definite about the diameter.
Any help greatly appreciated
A bit confused!
*** POLITE NOTICE*****
Having read various threads (and the responses) I am not asking for your opinion on WHETHER I should lower it, add coilies etc. I'm just asking HOW. There is a big difference. So please if you all you want to do is tell me what I should or should not do to my car in a general sense, then please, don't waste your breath or my time. Thanks***
