E30 m30 e28 wiring help needed pls
Fatboy15
Post Sat Feb 08, 2014 3:05 pm
Hi guys I've fitted an m30 3.5 to my e30 , it was originally from an e28 I'm struggling to sort the wiring I've got the car turning over and power to the coil from the wiring diagrams on here but believe mine is wired different as it has the speed and crank sensors on the gearbox area .. I have no spark and really struggling any help would be much appreciated ,
to make things a little more awkward I don't have the e28 rectangle engine loom plug the goes into the e28 fuse box I just have wires due to my mate needing it for his new engine . I have just been trying to wire e28 loom to the m20 round c101
Fatboy15
Post Sat Feb 08, 2014 3:29 pm
After just reading rob0r blog think I may just pull the lot out .. After needing servo pipe as e28 are hydraulic braking servo . Hadn't thought of this !!
Fatboy15
Post Sun Feb 09, 2014 11:18 am
Thank you I will give this a try ..
