AC compressor removal
Cloggy Saint
Post Wed Feb 05, 2014 8:34 pm
What's the deal with this, if I remove the pipe will the gas escape? Cheers.
Post Wed Feb 05, 2014 8:51 pm
It will if there's any in there. Considered to be a most heinous crime these days.
Cloggy Saint
Post Wed Feb 05, 2014 8:59 pm
It's as good as full, is there no way of avoiding this?
Post Wed Feb 05, 2014 9:05 pm
You suck it all out beforehand, using the correct equipment.
hazd31
Post Wed Feb 05, 2014 9:09 pm
Undo pipe untill hissing starts. Run. Come back later. Job jobbed
Cloggy Saint
Post Wed Feb 05, 2014 9:21 pm
I don't actually need to remove the compressor as such, I want to pull the engine out so I suppose I could remove it from it's bracket and tie it off some how ...
Post Wed Feb 05, 2014 9:59 pm
Cloggy Saint wrote:I don't actually need to remove the compressor as such, I want to pull the engine out so I suppose I could remove it from it's bracket and tie it off some how ...
That's how everyone else does it!
