LSD Units - Ask me anything.
davethegoat
Post Tue Dec 10, 2013 6:20 pm
Demlotcrew wrote:Could you do me a favour and take a photo of the pulse disk at the opposite end from the cap. :)
No problem. Do you mean the pulse disc for the speed sensor?
Demlotcrew
Post Tue Dec 10, 2013 6:22 pm
Yup that's the one.
davethegoat
Post Tue Dec 10, 2013 8:01 pm
Here y' go.
I'll give it all a clean perhaps tomorrow. Let me know if you want more pics. It should be easier to photograph with it not covered in old oil residue. :)
gareth
Post Wed Dec 11, 2013 1:00 pm
I'd replace those plates personally. They tend to glaze up then finally once they wear through the very thin coating, chew themselves to death and fill the oil with shredded metal. Then it's full rebuild time once the bearings run in the residue...
A lucky find though :D
Demlotcrew
Post Wed Dec 11, 2013 1:09 pm
Thanks for the photos :)
davethegoat
Post Wed Dec 11, 2013 7:50 pm
Thanks Gareth. Yep, a lucky find indeed! I've e'mailed driveandtraction.co.uk for a price on a set of plates. I'd be interested to hear any other/better options if there are any. :D
Cheers!
BTW, I'm sure I read somewhere that the plates are the same as the 2 plate units? Is that correct?
Demlotcrew
Post Wed Dec 11, 2013 10:48 pm
Actually the clutches come in different thicknesses and compounds.
Just measure the current plate, think they are 2.0mm and order accordingly.
davethegoat
Post Thu Dec 12, 2013 9:42 pm
The dog ear plates are in decent condition. Here's one after about twenty seconds with a bit of scotchbrite:
I've ordered a new set of friction plates. :D
Cheers! D. :D
davethegoat
Post Sat Dec 21, 2013 12:29 am
So, my plates turned up (super quick as it happens :D ):
So I popped them in. All back together with new (deeper headed) cover bolts:
Tada! :D
I'll fit some decent rear and side cover bolts at some point soon. 8)
Let me know if this is cluttering your thread up too much Demlotcrew and I'll edit it down. Thanks again for yours, Gareth's and DanThe's help/input! :thumb:
Cheers. Dave. :D
Demlotcrew
Post Sun Dec 22, 2013 11:50 am
No not at all Dave!
More content the better :) Glad you got it all sorted, when will you be testing it? :)
davethegoat
Post Mon Dec 23, 2013 11:49 am
I've got a few bits and pieces to do to the rest of the car, but hopefully it'll be ready to drive in a week or two (depending on how much of this festive nonsense I can get away with ignoring. :roll: )
Cheers! :D
Stevevrs
Post Fri Jan 31, 2014 11:01 am
Hi, i have an LSD on my 4 door but the tab is missing so not sure what one.
The diff has quite a bit of backlash causing the motor to hunt a little at times, is it worth having rebuilt ? if so any idea on price or is it an easy DIY job.
Its fitted to a car im selling shortly but i was wondering if it was worth the effort having it rebuilt and fitted to my Cabby project.
Steve
Demlotcrew
Post Fri Jan 31, 2014 11:31 am
If its quiet, then sorting the backlash should be no more than £100 from a professional.
Andrew
Stevevrs
Post Fri Jan 31, 2014 11:58 am
Demlotcrew wrote:If its quiet, then sorting the backlash should be no more than £100 from a professional.
Andrew
Its not bad, a little whine maybe but probably only noticable because i have no carpet in it.
Can you recomend anyone, i'll be taking it out next month
thanks
Steve
Demlotcrew
Post Fri Jan 31, 2014 12:02 pm
You should not be able to hear any differential noise, even with the seat/carpet out. If it's whining then it needs new bearings.
Give Gareth a PM on this forum.
Andrew
Stevevrs
Post Fri Jan 31, 2014 12:19 pm
Thanks Andrew.
Steve
