Car Battery Which 1 to get?
no1_jazz
Post Sat Jan 25, 2014 2:52 pm
Afternoon Zoners,
Just a quick question on car batteries. I have as you all probably know a standard 318iS M42. I am in need of a new battery.
I had a quick look at the ecp site and came across 2 which I think would work fine. The two are:
1: http://www.eurocarparts.com/ecp/c/BMW_3 ... 821&000020
2: http://www.eurocarparts.com/ecp/c/BMW_3 ... f4c&000020
Which one should I get out of the two above and or should I stay away from both?
If so which one do you all recommend.
J
no1_jazz
Post Sat Jan 25, 2014 5:53 pm
anybody at all ..... 8O
jimbom30cab
Tech 1 freak
Post Sat Jan 25, 2014 5:55 pm
Just get the biggest one that will fit in the battery tray
bmw9818
Post Sat Jan 25, 2014 7:19 pm
^ +1 096 iirc is the biggest that fits in the engine bay, in the rear you can get a massive one, which ive got with ridiculous power,
no1_jazz
Post Sat Jan 25, 2014 7:51 pm
Thanks Guys
I have gone for this one and i hope it is good enough:
http://www.eurocarparts.com/ecp/p/acces ... &0&cc5_997
I would one day do a rear battery conversion one day.
Thanks again ;)
Topblag
Post Sat Jan 25, 2014 8:00 pm
Get a decent one from your local scrapyard for £15 and buy a cheap charger from aldi or lidl and it'll last fine.
Recycling is the way forward.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
TheDutch
Post Sat Jan 25, 2014 8:17 pm
no1_jazz wrote:Thanks Guys
Thanks again ;)
£104! I hope you popped a discount code in. I am about to get a new battery for my 318iS, an 065 type which I believe is correct for the vehicle, ~£45 for a Bosch one. If you change your mind, you can just return the one you've ordered.
Here: http://www.carparts4less.co.uk/cp4l/p/////?444770655
...and use code SAVEME75 at the checkout.
no1_jazz
Post Sat Jan 25, 2014 9:29 pm
Thanks again ;)
Hi mate,
The one I am about to order comes to a total of 73.08 inc delivery this is for the S5 027 battery and this is with a 30% discount the code is (RENEW30).
I presume both will work fine, I have nothing in the car that will drain the battery. The car is fairly standard, no sounds no electrical extras.
Having just checked the same S5 027 on car parts for less the total comes to £64.74 inc delivery that's a saving of £8.34. A nice little result there.
What are the differences between the S3 065 and S5 027 ?
I would go to my local breakers if they still existed seems as if most London yards have seemed to perish away.
:cool: 8) 8)
TheDutch
Post Sat Jan 25, 2014 10:53 pm
The one you've ordered has a longer guarantee and a higher capacity. Should work well, but would be an unnecessary expense for me.
Post Sun Jan 26, 2014 12:16 am
Exactly the same battery, from the same warehouse, picked and packed by the same people, using the same order code, will cost you £65 from CP4L, if you order something else at £5 at the same time.
no1_jazz
Post Sun Jan 26, 2014 12:15 pm
Thanks Brian, I made the order with CP4L and now I await delivery. 8)
