God knows where the rest of it is!
How long do decent pumps last, oh wise one?rich318i wrote:they are crap pumps just tin with spot welds shocked it even did 100k even more shocked you used one dan
DanThe wrote:How long do decent pumps last, oh wise one?rich318i wrote:they are crap pumps just tin with spot welds shocked it even did 100k even more shocked you used one dan
As per usual your making no sense at all, the pump was new 100,000 miles ago, I fitted it myselfrich318i wrote:DanThe wrote:How long do decent pumps last, oh wise one?rich318i wrote:they are crap pumps just tin with spot welds shocked it even did 100k even more shocked you used one dan
Not being wise just common sense to of changed it once bought if you dont know when it was last changed!
not a hard job really
you would really let a water pump do over 50k whats make of tinDanThe wrote:As per usual your making no sense at all, the pump was new 100,000 miles ago, I fitted it myselfrich318i wrote:DanThe wrote: How long do decent pumps last, oh wise one?
can you read why on earth would you let a pump to run to 100kDanThe wrote:Can you read?
you have a point, I will change mine after 99k just to be safe,rich318i wrote:why on earth would you let a pump to run to 100k
because they are shit brand pumps made of tin and spot weldsross_jsy wrote:If it's pumping coolant and the bearing isn't grumbling, why would you change it Rich?
Go and ask the race team building your engine
Legoross_jsy wrote:KWP's are pretty decent pumps.
What you using in your world changing build then?
Pray do enlighten us mere mortalsrich318i wrote:better parts than that brand any way
rich318i wrote:
Make it up as you go i bet
.... and how often, or at what mileage will you be changing yours?rich318i wrote:better parts than that brand any way
He won't, his 'race' team will.gooner1 wrote:.... and how often, or at what mileage will you be changing yours?rich318i wrote:better parts than that brand any way
Some say he changes his Water pump every 1000 miles,ross_jsy wrote:You mean the Stig?
