throttle cable
moggie
Tue Jan 14, 2014 7:51 pm
can anyone tell me which throttle cable fits the e30 s50b32 swap the best ?
moggie
Thu Jan 16, 2014 10:00 am
ive ordered the e34 525 cable hope it fits
maynee007
Fri Jan 17, 2014 9:24 pm
it doesn't....tried today, it's well too short. the e30 one only just falls short of reaching so I've been advised to use z3m one. It seems the e30 one is more for the m50/2 conversion.
jmc330i
Fri Jan 17, 2014 9:55 pm
Its been a few years since I did mine, but there wasn't an off the shelf cable that fits.
I know one option was to shorten an S50 cable, but I used the standard S50 cable and moved the bracket on the inlet runner.
James
'91 325i Sport
'93 318i touring 16v
moggie
Sat Jan 18, 2014 8:58 am
your right it doesnt fit the e34 cable just bought it brand new from bmw :cry:
toadster987
Wed Jan 22, 2014 10:16 pm
I think I shortened the e36 cable by cutting the crimped end off , cut the cable to the right length then soldered the end back on
Uploaded with ImageShack.us
jmc330i
Wed Jan 22, 2014 11:27 pm
jmc330i wrote: I know one option was to shorten an S50 cable, but I used the standard S50 cable and moved the bracket on the inlet runner.
James
'91 325i Sport
moggie
Thu Jan 23, 2014 7:22 am
ive ordered the s50 cable jmc,im guessing you just moved the bracket to take up the slack in the outer cable? i will get what you mean when i test fit it i reckon.bmw kindly swapped it for the e34 one i bought for no extra charge :) should be here today
moggie
Thu Jan 23, 2014 7:31 am
if your on facebook jmc search bmw e30 s50 swap
ive done a little build page,i will try and put it up on here when i get round to it.
jmc330i
Thu Jan 23, 2014 12:49 pm
moggie wrote:ive ordered the s50 cable jmc,im guessing you just moved the bracket to take up the slack in the outer cable?
Yup, exactly that. A picture speaks a 1000 words....
The grey metal strip was mounted to both studs on the inlet runner and extended back to support the black bracket. Looking from the passenger side (as in the pic), the front hole of the black bracket mounted to the rear stud on the inlet runner. The rear hole of the bracket was riveted to the grey metal strip.
The pic wasn't the finished item, it all got trimmed and tidied.
It would've been easier to shorten the cable, but I like the idea of being able to buy and fit a standard item where possible - something that helped me when the original knackered cable snapped whilst I was 25miles from home, but (luckily) a 5min walk from the nearest BMW dealer.
James
'91 325i Sport
toadster987
Thu Jan 23, 2014 1:40 pm
Tidy job....... 8O
jmc330i
Thu Jan 23, 2014 5:19 pm
toadster987 wrote:Tidy job....... 8O
jmc330i wrote: The pic wasn't the finished item, it all got trimmed and tidied.
Everything in that pic was there for mock-up - note the E30 master cylinder that doesn't fit and the lack of inlet runners on No.6 and No.3. The extension for the throttle cable was eventually made from a single piece.
I think that pic was taken back in 2003/2004. I never did do the finished pics, but it was all tided away nicely thank you.
James
'91 325i Sport
moggie
Fri Jan 24, 2014 5:41 pm
so i ended up not moving the bracket,i didnt like how long the cable showing looked,the cable i bought had a long piece of metal crimped on the end of it with just the end flared to stop the nipple coming off,i just welded a new flared end on a third of the way up and filed it to the same shape as the original flared end,looks factory :)
