M30 white plug under dash
seanboy
Sun Jan 19, 2014 1:25 pm
Hi guys nearly there with this lump!!
Under dash the m30 loom has a white four pin plug.
I have from the 88 325i touring a double plug which looks like the top half of that plug could work?
I cut the white plug back and plugged into the suitable half of the double 4 pin plug but nothing happened.
I'm stuck lads
Sean.
seanboy
Sun Jan 19, 2014 1:28 pm
Would an existing I mobilizer have an issue with the M30's ECU??
Bristol_Jer
Sun Jan 19, 2014 6:35 pm
Have you got any pics of the plug and loom?
seanboy
Sun Jan 19, 2014 6:50 pm
Pulled the imobilzer out and it's sorted,
Took 5 min to disconnect :o
Green cable under fuse box spliced and black/yellow put back onto ignition connector block!
