Un-blocking Sunroof drains.
loogie
Thu Jan 16, 2014 3:30 pm
Hello, Looking for some advice please. My Sunroof is leaking has anyone got any tips for unblocking the back two drains?! The front ones are easily accessible, but I think I need to unblock the back ones?! I get the impression water isn't draining away fast enough. When i drive it starts to drip.
Thanks in advance.
Topblag
Thu Jan 16, 2014 3:45 pm
I'd use an airline from the sunroof to blow any blockages out. If that doesn't work, try some wire a hook or something similar and try from where the drains exit in the rear if the car.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
loogie
Thu Jan 16, 2014 5:01 pm
Not sure where the exit point is! Any directions?
Grrrmachine
E30 Zone Wiki / Team Member
Thu Jan 16, 2014 5:04 pm
The plastic parts in your rear wings. You'll see them in your boot, behind the carpet.
BenHar
Thu Jan 16, 2014 6:48 pm
Plastic strimmer cord is ideal for this.
Ben
Thu Jan 16, 2014 7:05 pm
Unless you regularly park with the sunroof open, I fail to see how a sunroof drain can ever get blocked. You can run something like TV coaxial cable or BenHar's strimmer line up through them, but I fear the word 'rust' will eventually figure in this thread.
loogie
Thu Jan 16, 2014 7:19 pm
Brianmoooore wrote:Unless you regularly park with the sunroof open, I fail to see how a sunroof drain can ever get blocked. You can run something like TV coaxial cable or BenHar's strimmer line up through them, but I fear the word 'rust' will eventually figure in this thread.
Was afraid of that. The outer edge of the sunroof is somewhat bubbled with rust, but the inner gutters running to the drains are in good condition, maybe the water is not reaching the guttering?! Thanks for your help.
Thu Jan 16, 2014 7:28 pm
Where does the water drip in?
jonesy318
Sun Jan 19, 2014 7:28 pm
Exactly how my sunroof issues started out, turned out the roof lining was holding the sunroof cassette up!!! 3 years later, a new sunroof cassette and multiple other panels and repairs its finally going back together, Good luck
loogie
Sat Jan 25, 2014 2:59 pm
The water seemed to be coming in below the stainless steel surrounds. I have tightened the screws, they were very loose, kind of hoping. the strength of rain we have been having didn't allow the water to drain sufficiently overflowing under the stainless surround....I know I am clutching at straws, sooner or later the carpet will have to come up to locate the source or sources! :(
loogie
Sat Jan 25, 2014 3:01 pm
Brianmoooore wrote:Where does the water drip in?
It was dripping from the roof lining inside of the sunroof onto our heads. Passenger side mostly.
Sanchez
Sat Jan 25, 2014 3:51 pm
Its it leaking from the rear of the sunroof?
Check the sunroof panels headlining bit is correctly fitted. The sunroof headliner has a metal gutter attached to the headliner.
Sanchez
Sat Jan 25, 2014 3:54 pm
Its the gutter looking bit numbered 1 but theres lots of number 1's.
Should be number 12 rain gutter trim.
Sat Jan 25, 2014 5:53 pm
You need to pull down the door rubbers and peel back the headlining on each side where it attaches to the door aperture and have a look , you will then undoubtably see the source of your water leak :(
