G-Bear wrote:
From Car parts 4 less
x2 Lemforder Mondeo rear droplinks £37.20 (the E30 ones are probably cheaper)
About the same price the last time I bought some.
x2 Lemforder Conrol arms complete £114
x2 Lemforder track rod full assemblies £64.68 (Use this part number as recommended by Meatballs 605110105)
These would only be replaced if they needed to be. New rubber boots on the control arm ball joints, and a bit of fresh grease added will give ones in good condition a whole new lease of life.
Track rods rarely need changing, and rod ends only occasionally. The new boot and grease works on them as well.
x2 Trailing arm bushes (because I could find them on CP4L, sure someone has the part number on here) £25.76
Again, very rarely need replacing. The 'muffin tops' that stick out at each end might have the odd bit of surface cracking, but the rubber where it matters is usually as good as new.
