Just picked up another E30 that has the 'splined' type locking wheel nuts, but there is no adaptor. I've got a few adaptors, but typically none of them fit.
Where would I find the code to get the right adaptor? I think there's some numbers on the nuts (inside the splines), but there's quite a bit of surface rust so can't make it out, but my guess would be they are what I'm looking for??
BMW locking wheelnut adaptor
jmc330i
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
Most dealers have a tray of the spline 'keys' IIRC there are approx 50 different types.
The number is on the end of the 'key' I cannot recall ever seeing it on a bolt. The other option is to get medieval with a 12 point socket on the outer surface of them. I have had success using an incorrect spline key and a big hammer BUT if it does not work , it is then too late to head to your dealer
jmc330i
Thanks Pete. This car won't be going anywhere near the dealer so I won't be able to try some out - it's definitely china bound
Talking of which, any idea what sort of price an M40 Cat will make at a scrappy?
Looks like I'll be buying some cheap sockets to get these locking bolts off!
James
'91 325i Sport
'91 325i Sport
maxfield
I've not failed yet on a set of locking wheel nuts with a hammer and chisel. I have damaged a few wheels mind, depends on how the wheel is designed.
maggspower
- Turbo Farmer Tractor Driver
The cats are the old school ones, and worth a few £££, I got £60 for the last one I had but there is a "Catman" that comes to the yard. Irish accent.
I have a locking wheel nut remover, propper outfit. However it is still fairly medievil, much hammering and swaring is encouraged
Seriously though its very good you are welcome to borrow.
Contact: theengineshedonline@gmail.com
jmc330i
Cheers Byron, I'll be in touch if I can't find something closer
Don't want to damage the wheels, they're the only reason I got the car!
That's good news on the cat price... I have a couple M40 cats plus one from a diesel 306.
James
'91 325i Sport
'91 325i Sport
harry_p
Enough room to put the end of a normal wheel bolt in the hole and get a bit of weld on them?
Never failed me, but depends how deep the nuts are in the wheel, and how shrouded they are.
cheers,
harry
harry
jmc330i
Welding is an option as long as it doesn't damage the wheels. Ill get my brother to have a look to see if there's enough room.
James
'91 325i Sport
'91 325i Sport
assassin
jmc330i wrote:Cheers Byron, I'll be in touch if I can't find something closer
This is what I use: http://www.ebay.co.uk/itm/SX200-SEALEY- ... 3a7a535256
Works on wheel bolts that don't have a loose outer sleeve.
sanitroc1
Hi James is this the blue one the same as mine ? . What are the drivers side doors like ? .
Just finished putting a e36 m42 in mine what a p i t a that was but all sorted now .
Re wheel bolts I am ashamed to say I have done the following but it worked .
Take one piece of board ( mdf or whatever ) and drill a hole in it in line with the bolt , get one long bolt that is bigger than the splines , insert bolt through board and line up with splines and tap with hammer to start it going in , take one sledgehammer ( you know what's coming ) and give it one heavy smack and undo bolt . The downside of this is getting the long bolt out of the locking bolt takes ages the first time .
Thanks Steve .
Thanks Steve .
jmc330i
Thanks everyone, one way or another the wheels won't be on for much longer!
Steve - no, not the blue touring, I've barely looked at it since picking it up. I picked up a 4dr with some clean 15" BBS on which I've already sold hence not wanting to damage them.
I'll have a look at the drivers door on the blue touring for you, I know the rear one is damaged, but can't remember if the front was caught.
James
'91 325i Sport
'91 325i Sport
sanitroc1
James if the moredoor is china bound what colour is it ? .
Thanks Steve .
Thanks Steve .
