Have you seen replacement pieces for these rusty areas for sale?
Grrrmachine wrote:Get used to using RealOEM - it will walk you through all of the parts you need.
With that said, I replaced almost every single part you've highlighted with my own parts fabricated from 0.8mm sheet steel. Otherwise you're looking at buying:
New sill
Rear valance
Rear wing
Right rear side member
The first two can be bought aftermarket, but the other parts are BMW only which will cost you $$$.
Actually, good idea. Somebody might need other half of that part I cut off.Grrrmachine wrote:You're not supposed to use the entire panel though; just cut off as much as you need.
I will be learning how to weld next week, got MIG welder already.Grrrmachine wrote:If you can't use a hammer and dolly, you shouldn't be using a welder.
