Hi A have fault that has developed today the car was working fine after a short drive, the car turned off and when trying to start it again it only runs for a few secs and then turns off despite putting having the accelerator pedal depressed fully.
There is plenty of fuel and it sparks when it turned over. I have changed the idle valve that made no difference.
Any ideas what could the problem here? any pointers/help greatly appreciated.
Thx
E30 316i starting problems
Tommek
Check the fuel pressure regulator, it might be broken. Disconnect the hose that goes to the intake manifold, if it's full of petrol, the pressure regulator diaphragm is gone.
Here are some explanations and diagnostic procedures:
http://www.e30zone.net/e30zonewiki/inde ... _Regulator
E30 Touring
Grrrmachine
- E30 Zone Wiki / Team Member
Don't go swapping or replacing anything until you've done some diagnostics first. Go through this chart to help:
http://www.e30zone.net/e30zonewiki/inde ... oubleshoot
Tommek
Yes, Grrr is right, you could have also a big air leak or any other fault. It is best to check like in the diagram
E30 Touring
TPS
False Air, I bet you.
Ch4ni
Thank you for all your advice, I will trouble shoot this at the weekend and report back.
