diagnostic port
alfa12177
Post Tue Jan 07, 2014 1:29 pm
hi anyone got a picture of the diagnostic port with numbers visible having trouble reading the numbers on mine .many thanks chris
Post Tue Jan 07, 2014 1:32 pm
alfa12177
Post Tue Jan 07, 2014 1:39 pm
thanks . :D :D :D
JF008
Post Tue Jan 07, 2014 1:52 pm
Does it mean you can't get a rolling road remap as there is no live data available?
Post Tue Jan 07, 2014 2:13 pm
You can't remap it via the diagnostic port; the EPROM chip has to be removed from the ECU and blanked, then re-programmed.
(Or just swap the chip for a pre-programmed one).
Modern cars have flash-programmable ECUs that can be reprogrammed via the diagnostic port.
