noisy PS pump
jimbom30cab
Tech 1 freak
Post Wed Jan 01, 2014 6:35 pm
Has anyone else used the m30 power steering pump. I have and its really squealy especially when cold starting. Its also a lot lighter on the steering than my m20 with PS.
just wondering if the pump is too much for the e30 racks and its cavitation i can hear, the oil is very aerate.
i've got a spare pump so might try that first if not then does anyone know if an m20 pump will fit?
jimbom30cab
Tech 1 freak
Post Wed Jan 01, 2014 7:33 pm
yes mate, all ok
mcbonio
Post Wed Jan 01, 2014 9:29 pm
Never had an issue with mine chap, is it bled properly?
jimbom30cab
Tech 1 freak
Post Wed Jan 01, 2014 9:35 pm
I don't know to be honest Chris, you know when you turn the wheel to the extreme and it squeaks a little as it bleeds. Well mine is like that all the time. Its not leaking oil.
beardymat
Post Wed Jan 01, 2014 9:40 pm
When I fitted the S50 in my old M3 It would bleed up fine but then get noisy again shortly after, turned out I had the supply and return pipes the wrong way around on the bottle. Swapped em round and all sorted.
jimbom30cab
Tech 1 freak
Post Wed Jan 01, 2014 9:48 pm
Legend, thanks, will give it a go
It's the kinda thing I would do
:o:
Cypriotgeeza
Post Wed Jan 08, 2014 12:05 pm
Does the M30 power steering pump match up with the standard rack + pipes with no modifications?
The m30 in mine has the power steering pump in the boot (never fitted)
Check my M30 build threads:
New Daily : viewtopic.php?f=34&t=285452
jimbom30cab
Tech 1 freak
Post Wed Jan 08, 2014 12:37 pm
Yes all fits fine but you need a m20 pipe from the tank to the pump
Cypriotgeeza
Post Wed Jan 08, 2014 12:40 pm
jimbom30cab wrote:Yes all fits fine but you need a m20 pipe from the tank to the pump
No problem! Thanx :thumb:
