Any ideas, can you operate the sunroof manually using the big nut on the motor or not??
Just want to see if I can coax it into working.
Slacken off the big nut first, to disconnect the motor drive from the gearbox.Sanchez wrote:If you remove the cover and see the motor then manually turn the motor with a allen key.
