m50b25 which cams?
JF008
Post Fri Dec 27, 2013 8:16 pm
Looking for aftermarket cams for a non vanos m50, can't say I found anything online apart from the Schrick US m3 ones but its really for the m52. ??
Any suggestions/links would be greatly appreciated.
Cheers,
JF
ross_jsy
Post Fri Dec 27, 2013 8:39 pm
JF008
Post Sat Dec 28, 2013 7:56 am
Thanks Ross, did look at cat cams before but never found that page! I'll have to ring them i think as now I can't find prices or places to order them...
Any Schrick cams successfully fitted to a non vanos m50?
JF008
Post Sun Dec 29, 2013 4:09 pm
I found the m50b25 non vanos cat cams (257°/250° - 220°/213° - 10.15mm/9.55mm - 1.00mm/0.70mm) to be the best value for money for £600 (VAC Motorsport), is it worth it to have upgraded cams on a 2.5? I enjoy driving very much but never swapped cams before.
I'm thinking the cams and a remap would add a few ponies and would ''finish'' the m50 project nicely, well for a little while at least.
Any upgraded cam driving experience review or advice much appreciated,
JF
rich318i
Post Sun Dec 29, 2013 7:17 pm
£600 put import tax on top as well
try
http://www.newman-cams.com/
http://www.kentcams.com/
Can make the cams to what ever spec you want
JF008
Post Sun Dec 29, 2013 8:23 pm
Cheers buddy, kent cams only does the e30 engines, I looked up newman and they are dirt cheap, I sent them an email thanks for the links!
rich318i
Post Sun Dec 29, 2013 9:38 pm
JF008 wrote:Cheers buddy, kent cams only does the e30 engines, I looked up newman and they are dirt cheap, I sent them an email thanks for the links!
ring them
01689857109
or better take a drive and see them,
if your in east Sussex just A21 all the away
the man who owns the place is called ken but also try and see the machinist maybe nice cash in hand job
Cook318IS
Post Sun Dec 29, 2013 10:06 pm
I believe Rally Prep deal with Catcams http://www.e30zone.net/modules.php?name ... le&u=25649
Post Mon Dec 30, 2013 12:35 am
Waste of money IMO, you could buy an M52B28 for less and have more performance
rich318i
Post Mon Dec 30, 2013 9:53 pm
DanThe wrote:Waste of money IMO, you could buy an M52B28 for less and have more performance
Not if you do a VANOS delete and use race spec cams.,which M50b25 dont have a VANOS
ross_jsy
Post Mon Dec 30, 2013 10:03 pm
What are you blabbing on about now Rich?
An m52 on standard cams without deleting VANOS and using an m50 inlet will make about as much power as "race spec cams" in an m50 and be far more drivable on the road.
rich318i
Post Mon Dec 30, 2013 10:12 pm
ross_jsy wrote:What are you blabbing on about now Rich?
depends if want to drive it on the road or just have it as just a 2000rpm at idle racer
Sorry didnt know you was a engineer at BMW's Plant Zero
ross_jsy
Post Mon Dec 30, 2013 10:14 pm
You really are thick aren't you :D
How's your world changing build coming along?
rich318i
Post Mon Dec 30, 2013 10:16 pm
ross_jsy wrote:You really are thick aren't you :D
all going great, Thanks for asking
JF008
Post Thu Jan 02, 2014 7:58 pm
I enquired to Newman about getting cams made to the cat cam spec above^^^^^, the answer was £1600. Just a thousand pounds more expensive then ordering the real thing which is made to order too, then shipped around the world. :?
rich318i
Post Thu Jan 02, 2014 8:10 pm
Fook that.. They having a laugh.
Keep your eye open on ebay
