e30 m20 turbo traction troubles
theoaks32
Hi Guys,
I'm looking for suggestions please on how to best get traction, I've built my M20 turbo convertible following all the info available on the site, thanks to one and all!
My problem is that as soon as I am above about 8 PSI we get wheel spin, in 3rd and upwards at full throttle on a damp road, and should I bravely/stupidly turn up the boost (highest I've dared is 14.5) I get wheel spin 3rd gear on a dry road, it all a bit bonkers!
So far the car is fitted with Spax RSX coil overs rear lowered by 40mm, I've changed the diff out for a 3.91 LSD (new oil and locks well, remember this is a convertible so originally had a 4.10) Its on 17" alpina reps with 215/40/17s with good tread.
What can I do, fill the spare wheel hole with concrete???
All suggestions greatfully received.
Cheers Andi
Cheers Andi
Don't drive at full throttle on a damp road.
theoaks32
You make a good point, but it does kick the fun out of it somewhat!
Grrrmachine
- E30 Zone Wiki / Team Member
A 3.91 diff is still on the short side as far as diffs go; I use a 3.64 in my Touring.
Your choice of rim won't be helping much, and you haven't mentioned what tyres you're running. Brand new linglong ditchfinders will still be shit no matter how much tread you have left.
theoaks32
I see your point with the diff I was just initially concerned about going too long as the convertible is heaviest of the e30s, and might have then been struggling to get off the mark, the tyres are Goodyear so about middle of the road.
craigieeb
There is your problem,theoaks32 wrote: the tyres are Goodyear so about middle of the road.
get some decent tyres
M50 Turbo!!!
I shall say no more
craigieeb
R888's,
Yokohama Ao48's,
Toyo R1R's..?
etc etc
Yokohama Ao48's,
Toyo R1R's..?
etc etc
M50 Turbo!!!
I shall say no more
theoaks32
Ok good stuff Ill take a look at the toyos, should I also be looking for a wider wheel?
craigieeb
What you running at the moment? 7j?
M50 Turbo!!!
I shall say no more
theoaks32
Hi there yes Im running 17 x 7s et 40
craigieeb
Even if you get a real good set of tyres at 215's
you'll notice the difference, instantly.
M50 Turbo!!!
I shall say no more
theoaks32
Am I better to be just looking at the 215s again, keeping cost down or as set of these toyos is already £600 Should I bit the bullet and go bigger on an 8 inch rim, do you know how big I can go sensibly?
ross2009
ive got 16x9s with faulken tyres with gaz coilovers poly bushed rear and a 3.64lsd and had over 400 bhp and never used to lose traction at all in the dry
theoaks32
Thanks for that Im beginning to feel that 16 x 9 is the way to go, what size tyres do you run?
ross2009
there 215 40 16 very very slight stretch on them
miniblob
Not running anything like your power, but on my 2.7 touring I'm running 225/45/16 rears on the schnitzer rims - new pair of Toyo's in the summer and superb grip since!!!
I can also highly recommend new tyres, as opposed to some 'lightly used' 'second hand' tyres I have had before on a budget - the rubber does go hard as it gets older, so no matter how good a tyre it was, after a few years it doesn't give anywhere near as much grip!!!
I'm also running a 3.91 LSD and am constantly debating/wondering if I'd be better off with something like a 3.64 - so with more power, I'd definately change it!!!
327 Touring with bass!!!
capnmchl
Reduce the rear camber and stop the rear from squatting under power.
No point putting wide or sticker tyres on if it's only getting contact across half the tyre face.
However, the big issue is the way the camber increases when the car squats when you accelerate.
theoaks32
Hi there thank you for you comments on camber, I have tried to keep the rear from squatting too much, by poly bushing the rear and using Spax RSX set to hard hard, and by keeping the ride height not too low, (-40mm) so at a stand still the rear is actually higher than the front and the wheels are virtually vertical, but as you quite rightly say once you use the loud pedal the rear squats still. Any suggestions?
ross2009
true to the degree of tyre surface on the rd but I haven't altered my camber on the rear and mine is just fine you need it to squat to gain traction as if it was to stiff it will just bounce and get what they call axel tramp but not so on the e30 as there independantcapnmchl wrote:Reduce the rear camber and stop the rear from squatting under power.
