Andy's 318iS / M52b30
JungleGus
It's a strange feeling seeing a photo of my knob in the internet...
Nice build! Love it - love seeing the progress
If you had held the throttle open the comp ratios would have been closer to 220psi
AndyZippy
Hehe i was just happy they were all so close
Ok so, few new toys started arriving now....
nice dampers ,i did like them on my car but cant run two sets
+ a yard full of scrap turds
AndyZippy
Hehe
Yea Mick, they've sorted out the issue i was having for sure
NoTurbo
WOW I cant wait to hear more...
Jamie8GTi
going to be fast!
some really great work going into this one! top job
AndyZippy
Cheers guys! I wanted to do an oil change today, and replace the PAS reservoir as i've bought a new one to replace the leaky one, but the weather here is a wonderful mix of strong wind and rain. Few more suspension bits on the way, have new lollipop bushes & brackets ordered, and new front ARB bushes. Bit by bit.. ;)
AndyZippy
Ok, been a while without updates, work was crazy over Christmas & New Years, and i've been away for two long weekends playing shows since NYE. But i'm back on it now..
First up, she'd developed an airlock in the coolant - took some 90 minutes to tease out, but ever since all has been well, and she is running even better. At first we'd thought it might be the thermostat, so changed it for new (went from 88 degree to 80 degree too). No overheating drama, as i caught the coolant blockage before it happened fully - luckily was being super vigilant waiting for the heater to blow hot on a cold drive! Anyway, running like a dream now - all good. I think maybe it just wasn't fully bled, and maybe a few little bits of air all finally converged at the water pump.
My old man even treated her to a clean and polish whilst she was over at their house, bless him..
In the meantime, i've been ordering the rest of the parts for rebuilding the front suspension, and started tackling the airbox, so i can finally get her on the dyno. Chopped off the wierd long triangular plastic bit and "welded" the end back in the hole flush with a soldering iron, removed the front air feed as it's a different shape the the round e30 feed, but it's still a bit of a packaging nightmare. Going to look for a nice airboot, a bit like danthe's, as it should lose me that inch i need back to fit it in...
Also needs a large dab of back-to-black, ha! K&N back in place for now.
i cut a hole out of the headlight backing cover to get the airbox to fit.Took a couple of trimmings but sits nicely now .
tha881
appletree
When did you order you brakes off Keri? I've been trying to get hold of him for a month or so with no success.
Did you get a number for him?
Nice work by the way
Matt
Matt
AndyZippy
Hey Matt,
Cheers mate! I actually bought them still new from a zoner, who happened to have bought the exact set up i wanted, but sold his e30 before fitting.
I've tried to get hold of Keri since though, emailed him on Boxing day i think, and have had no reply.. Is he still trading i wonder? :/
mathew325
so what propshaft did you use and also how did manifold ?
AndyZippy
Standard E30 325 Propshaft matey - Danthe did my exhaust manifolds, and Infinity did the downpipes onwards
rich318i
any rolling round news yet?
rich318i
depends on what gearbox you are using, and the manifold is easy if you know a good garage.mathew325 wrote:so what propshaft did you use and also how did manifold ?
Not knocking dans work but i seen his work from some one that got them from him and the manifold was good but the flanges (not even flanges just a welded straight pipe, clamps combo) were pointing to the floor. Mods had to be done for it too fit, it was way off
cutting a 15 ish decree cut and bending it at number 6 and welding it doesn't justify the cost of just cleaning the rest and making it shiny
ross_jsy
Rich, no doubt one of your equally retarded mates. Dan's manifold mates up perfectly to a 3 piece exhaust system as used by me, and many other zoners without problems.
rich318i
it was way off and the person had the M20b25 exhaust aswell so should of fit like a gloveross_jsy wrote:Rich, no doubt one of your equally retarded mates. Dan's manifold mates up perfectly to a 3 piece exhaust system as used by me, and many other zoners without problems.
Maybe you should start selling them yourself if they are so easy and mine are so shit?
Or was that the drugs talking?
AndyZippy
Guys, let's not turn this into another one of THOSE threads, this is my build thread! ;) Rich, everything Dan has done for me has been spot on - his exhaust manifolds are excellent, and I'd much rather have done what i did, by paying Dan for that and Infinity to build my beautiful custom stainless system than mess around cutting, bending and welding pipes myself, which would have looked crap anyway. If you've had issues, contact the man himself - To be honest, I've seen build after build on here with praise for dan's work.
RE rolling road - I'm currently awaiting a samco silicon elbow, once that arrives and the airbox is in, it will be time! If anyone can recommend a good accurate rollers around Bristol I'd be all ears. I know Fritz have one, which is pretty close to me
Contact Paul Sheppard mate, Circuit Motors
mathew325
one more question what abut loom how did that
AndyZippy
Thanks pal, i shall look him upDanThe wrote:Contact Paul Sheppard mate, Circuit Motors
AndyZippy
Hey man, Danthe (post above yours) did both my engine loom and my auto fan loommathew325 wrote:one more question what abut loom how did that
AndyZippy
Got around to changing the PAS Reservoir this afternoon - Seems the old one was leaking from the seam, not the lid or bottom like we thought. Also had it's oil change at the same time, finally - Mobil 1 now doing it's thing. Hoping to get the front struts off next week. Progress!
Jamie8GTi
That paint comes up like new!
This is one hell of a sleeper!!
Neilios
and the Dyno results are?
AndyZippy
Still waiting on the Samco boot Neilios! The constant rain stopped play quite a bit, managed to do the front drop links before getting soaked, and have been busy since the nice weather hit - Hopefully get to crack on plenty next week now! Considering having a proper remap whilst up getting dyno'd too - Need to give Circuit Motors a ring once i have a boot eta
jimbom30cab
- Tech 1 freak
Hey Andy, did you get chance to RR it?
cheers Jim
cheers Jim
Quaser
as above ^^
reggid
x3
E30 325is with M20B31
AndyZippy
RIGHT! Time for a long, LONG overdue update! Life got in the way, driving got in the way, etc etc.
SO back in march the ICV hose split - Running the M52 w/ M50 inlet conbination seems to put a little strain on it, so we fab'd up a slightly adjustable one, so that once the Samco elbow was fitted it could be adjusted to fit that too. Whilst the new hoses were on order, i already had replacement suspension parts so thought i'd get stuck into that - chassis rail lollipop bolt sheared. SO, as we were working on the car on days off, the tyres needed replacing so i bought a set of Toyo Proxes and sent my tatty 15" BBS off for a refurb.
Problem? The refurb chap hadn't paid his unit rent - and the landlord impounded everything in his unit! Including my wheels. Meant we could take a bit longer over the suspension, but the car was on ramps for nearly 4 months! I finally got my wheels back as the guy's landlord realised we were genuine and a pal of mine said the business next door to his Kwik Fit MOT station could give them a quick refurb for £120 all in as a favour to my friend.. By that point i was done so went for it. Blast and powder coat, sorted. Though the idiotic blaster blasted the middle plastic parts of the center caps too so they are wrecked!
Anyway, all woes aside, progress has been getting made....
Quick recent pic (Spy another family car that needs a little work.. Mazda 323f V6) - note lack of centre caps ;)
Whilst she was up in the air we changed the rear beam bushes too - Standard Lemforder OEM ones but with plastic spacers inserted too. Rust free inside the bush bores, and treated the rear beam to a coat of paint too. Did them in situ... we fabbed up this tool..
Much better, as the old ones were shot!
Onto the front.... Out with the old:
BRAND NEW:
Wishbones
Drop Links
Lollipop bushes and carriers
(poly) ARB bushes
Bilstein B4 Dampers
Top Mounts
(Refurbed) Struts
Spring seats... You get the idea. EVERYTHING! I even sprayed up the APEX 30mm drop springs. We realised, after checking the code, that they were 4-pot, not 6-pot 30mm drop springs. We fitted them for now, with a view to fitting H&R whilst she is laid up over winter. Treated the Front ARB and dust covers to a wire brush a lick of paint too. More DIY solutions...
Polybushes are horrid to fit..
Fresh underseal too.
WMS still to fit as other things required attention so still on it's standard iS/325 brakes - Will go on over winter along with the new springs.
Also planned are:
2 refurbed trailing arms
New trailing arm bushes
New rear arb bushes (poly)
Refurb rear arb.
FIT SAMCO HOSE!!! Holding off on a remap/rolling road as on the hunt for some S52 cams, so can do the whole load in one go. Apologies to everyone wanting a power/torque figure!!
And then winter fun of:
* Body work - fit the new wings, new front valance, (finally) iS Splitter, new rear valance, tidy up sills and any bubbles, and full respray! (Same colours). Also considering one of those LWS carbon fibre full replica bonnets too, a 20KG saving up front would be rather lovely.
* New (crack free) dash
* Get rid of remnants of old alarm
* Fit new alarm!
* About 700 other jobs that need doing / are yet to be discovered! I know it's a bit of a naff update, more to come!
BRAND NEW:
Wishbones
Drop Links
(poly) ARB bushes
Bilstein B4 Dampers
Top Mounts
(Refurbed) Struts
Also planned are:
Refurb rear arb.
* Fit new alarm!
AndyZippy
Also just picked up some US M3 Cams
LondonTom
Love this build - did you ever got it on the rollers?
