When I touch the accelerator from idle revs dip right down to around 500rpm then they pick only happens from idle.
Any ideas?
Many thanks in advance
Thankyou very much will give it ago today.Speedtouch wrote:Try spraying WD40 around the inlet manifold gasket with the engine idling; if it briefly raises the revs, then you have a leak.
Also check all inlet hoses for splits, and clean the idle control valve and clean/adjust the throttle position switch;
http://www.e30zone.net/e30zonewiki/index.php/Intake
