Got a e30 here with a m52
building up a hell of alot of pressure
any ideas?
Bled the system a few times,not overheating at all
m52 help
SHAZ325iSPORT
rich318i
seems like that time of year everyones having cooling problems or leaks.
get a new rad cap first off
You loosing any water?
SHAZ325iSPORT
rich318i
in what way is it over pressuring then?
SHAZ325iSPORT
rich318i
when up to temp?
what rad you running?
wullie325i
- CAUTION - unreliable trader!
when did it start i.e had you drained it then filled as they are a pig to bleed up correctly and end up cracking expansion chambers if not watched over when bleeding
SHAZ325iSPORT
At 2 bar, the hoses should be 'rock solid' - 30 lbs pressure for every square inch of hose area.
If the PRV in the coolant bottle cap isn't blowing off, then there's no problem, unless the cap is faulty.
wullie325i
if its leaking from there it most likely didn't get bled correctly in the first place, did this with the first m5x engine i bled and cracked the expansion tank oops.
get a new expansion tank on it and bleed it up and you should be all good assuming theres no other issues with the cooling system.
