twin pipe, single pipe?
Rodfromgod
Hi, my single pipe fuel pump packed up and left me stranded, whipped one out of a breaker but it has twin pipes on the top. Is there anyway this can still be safely used or do I need to buy a single pipe one. Many thanks.
You can change the actual pump over, which involves soldering two wires, (get them the right way around - ask daimlerman), or you can blank the second pipe off. This is best done with a short piece of fuel hose, a short piece of solid rod of some sort, and a couple of hose clips.
Rodfromgod
Thanks for taking the time to share your extensive knowledge with me have blanked it off for now, you got me back on the black stuff.
