Drivers Window Switch
Pal318is
Post Wed Dec 04, 2013 6:42 pm
My drivers window had stopped working. I've checked the fuses and swapped over the switches too, however this has still not fixed the issue.
Any ideas as its getting colder :cry:
Pal
Image[img]http://Image
polsta
Post Wed Dec 04, 2013 6:59 pm
regulator, and or the motor in it
Pal318is
Post Thu Dec 05, 2013 2:21 pm
Will give it go today, I can't remeber what regulator it is, but have a diagram :)
Pal
polsta
Post Thu Dec 05, 2013 2:41 pm
a regulator is the big scissor thing with motor on it, that lifts the window- door card off have a look, see if the teeth are worn etc
Pal318is
Post Thu Dec 05, 2013 4:59 pm
Thanks bud :cool:
Pal
scallyally
Post Thu Dec 05, 2013 6:02 pm
Door loom connector in A pillar may be corroded, I removed rubber cover and sprayed pins with W-D40.
It helped. (I couldn't remove plug, might search the wiki) :D
Pal318is
Post Thu Dec 05, 2013 9:39 pm
I've checked the regulator and the motor and they both work fine. I've got the window back up, by using a battery and connecting it directly to the motor.
Will check the a pillar tomorrow, thanks for the info. I've checked the wiki and tried the tips on there already, but no help.
Pal
Pal318is
Post Sun Dec 08, 2013 12:39 pm
Typically the switch has now started to work :?
Pal
