pud1
I went outside , took the cover off, drove it over the Beacons for an hour or so, took it back, put the cover on and decided it was time for it to go to another home. I think I have just realised I need a proper everyday car rather than a showpiece.
Just like Mr Webber, time to go is when you are at the top rather than sliding down the slope into obscurity and the knackers yard.
BROOMY
- busy saving Clifford
You got a link ? I threw the battery away so cant look at itSpeedtouch wrote:What, literally?BROOMY wrote: Plus maybe redo the alarm as the battery exploded.They are replaceable - usually a Ni-Cd or Lithium type available from the likes of Maplin, CPC, etc.
Well, I hope you took note of what type it was, prior to discarding it!
Batteries available here:
http://www.maplin.co.uk/c/batteries-and-power
http://cpc.farnell.com/batteries?isRedirect=true
http://uk.rs-online.com/web/c/batteries/
http://www.ebay.co.uk/sch/i.html?_trksi ... &_from=R40
Or here:
Or here:
buster
Fitted a new sunroof pannel. Quite easy, getting the interior cover back on was a bitch.
gooner1
- Out humping Reindeer
You have a PM.pud1 wrote:I went outside , took the cover off, drove it over the Beacons for an hour or so, took it back, put the cover on and decided it was time for it to go to another home. I think I have just realised I need a proper everyday car rather than a showpiece.
sorned it !
+ a yard full of scrap turds
rich318i
found out my heater matrix as gone or heater value
and found some rust behind the fuse box and water in foot well fingers crossed its just from the heater
FOOKING CARS !!!
FOOKING CARS !!!
Filled it with most of the contents of my garage, put £10 of Shell's finest unleaded in and drove it to my parents garage where it will stay for the next 2 weeks until it gets its new home
- **BANNED**
You need to lift the rear of the liner as you slide it forward,this engages the liner's tilt bit....as the actress said to the bishop....and enables the liner to slide fully forward...as the,well,you should understand what I mean!buster wrote:Fitted a new sunroof panel. Quite easy, getting the interior cover back on was a bitch.
buster
Yeah cheers figured it in the end. It wouldn't engage at the rear so I tilted it and poped it back onto the runners from out side then slid it back and it pulled forward to engage the pin thingys.
StuBeeDoo
StuBeeDoo
pud1 wrote:I think I have just realised I need a proper everyday car rather than a showpiece.
........... time to go is when you are at the top rather than sliding down the slope into obscurity and the knackers yard.
(See my post above)
ah
It can't be that bad!
Born on the 23 April 1990 320i Alpinweiss ll kabriolett! (SOLD BUT NOT FORGOTTEN !)
StuBeeDoo
Depends on your interpretation of "bad".ah wrote:It can't be that bad!
I've thrown in excess of £6k at that car in the last 4 years, including a full engine rebuild and a £2.5k respray - at which point the only things that let the car down were car park dings. Structurally, the car was solid. Within 2 years the inner wings, chassis rails, battery tray, front valance, crossmember, floor and rear lower panel, 2x doors and the tailgate all developed serious tin worm.
It needed all the rear suspension bushes replaced (including the beam), rear top mounts, rear discs, pads and handbrake shoes.
The HRW was totally inop despite having power to it, and a good earth - that'll be a new screen needed, then. The rear washer pumped water into the boot, the headlining had started to sag. Then there sundry other little niggles as well.
Now, I call that bad! I don't have the luxury of being able to run more than one car, so doing what would have amounted to a nut & bolt restoration on the E30 was out of the question. ......Plus I paid for my E46 roughly half of what I would have needed to spend on a restoration.
For me, particularly as I'm becoming physically less able to do much of my own mechanical work, running a 24 year old car as a daily driver is no longer viable.
So, yes, it is that bad. But having said that, I'm as happy (maybe even happier) with the E46 as I was with the E30 when I first bought it. .........But I won't fall into the trap of trying to keep it on the road past its sell-by date.
........And then there's the fuel economy..........
rich318i wrote:found out my heater matrix as gone or heater value![]()
and found some rust behind the fuse box and water in foot well fingers crossed its just from the heater![]()
********* CARS !!!
Gutted for you ! Any pics ?
shedrool83
breakermart
sent my 325 flywheel off to be machined and put in my 328. that is all
think its the most progress my car has had In months
Cypriotgeeza
Check my M30 build threads:
gooner1
Got the remaining bitch of a wishbone off.
.........But I won't fall into the trap of trying to keep it on the road past its sell-by date.StuBeeDoo wrote:ah wrote:It can't be that bad!
quote]
Really Stuart?
StuBeeDoo
You could have a weekend toy with no pressure to keep it on the road.
My e36 318ti has been the best car I have ever owned for lots of reasons but I`m really excited with the addition of the Baur. I can take my time with this one because it is what it is and must be kept standard which means less pressure.
StuBeeDoo
I know lots do, but it's not an option for me. I actually got very close to buying a TR6 a couple of years ago, though, until I realised a couple of things.........martauto wrote:You could have a weekend toy with no pressure to keep it on the road.
1) I don't have space to keep another car. Most of the households around me have at least 2 cars and it's always a nightmare trying to get parked. When these houses were built (1903) parking family cars was unheard of for the people living here.
2) I can't justify to myself the running costs for another car when I already have one that does all I want. I don't drive for the hell of it, I don't have the time for that luxury - I do all of my driving out of necessity.
I'm done with cars as a hobby/plaything. I won't be going back there anytime in this life.
- E30 Zone Meets/Events Team
milescook
Made a todo list:
Fix fuel guage
Fix temp guage
Fix central locking so I don't have to turn key in passenger door, pull handle at the same time, switch on ignition and pull the driver pin up :s
Fix heater switch - stuck on hot,
Re wire high level brake light to come on with brake lights when the headlights are on as well as off,
Cambelt / water pump replacement,
Replace (new parts sitting on the kitchen table) wishbone bushes, tie rod ends, droplinks,
Source and fit 2nd seat,
Address rust spots,
Replace arb bushes,
Replace steering boss with a shorter one (wheel too close),
Extend spray of home made windscreen washers,
Replace fuel filter, part waiting (old one possibly fitted wrong way round)...
may have missed some
It's only a track car but am having to commute some of the week. Could also do with a cushion!
Fix fuel guage
Fix temp guage
Address rust spots,
Replace arb bushes,
Also please help the race budget by watching some videos
https://www.youtube.com/cookracinguk
darkchild
Winter wheels fitted today. I'd forgotten how hilarious the old barge looks on such skinny rubber. Ride comfort is immense though with 70 profile tyres. The Goodyear Ultragrips are so quiet as well, tyre noise is non-existent.
shedrool83
jimbom30cab
- Tech 1 freak
FZB
Took my daughter and her friend to ice skating in it, took the friend's yummy mummy to work in it, 10 miles or so.
Mark B.
1990 E30 318is
2013 E92 M3
1990 E30 318is
2013 E92 M3
jimbom30cab
- Tech 1 freak
got a pic of the yummy mummy?
Cypriotgeeza
+1jimbom30cab wrote:got a pic of the yummy mummy?
FZB
Unfortunately not but as my daughter is half Chinese and her friend is full Chinese you can probably see where my fancies lie
Cypriotgeeza wrote:+1jimbom30cab wrote:got a pic of the yummy mummy?
Mark B.
1990 E30 318is
2013 E92 M3
1990 E30 318is
2013 E92 M3
Prawn Crackers?
I had some Chinese for dinner tonight, and also walked a Chinese Shar Pei, then set up a new Canon printer made in China, coincidentally.
FZB
Went Christmas shopping. The boot is now the hiding place for all Christmas pressies.
Mark B.
1990 E30 318is
2013 E92 M3
1990 E30 318is
2013 E92 M3
gooner1
Fitted the remaining new wishbone and control arm bushes with
uprated M3 eccentric bush.
Washed, claybarred and polished the turd. M10's need some tlc too.
