Engine stand bolts for m20?
DanTheMannn
Post Sat Nov 30, 2013 5:55 pm
What size bolts do you need to put the m20 2.5 lump on a stand?
cheerzzzz
jmc330i
Post Sat Nov 30, 2013 6:16 pm
I usually use the gearbox bolts. No idea on size, but M10 and M12 sounds familiar... Realoem or BMWfans should be able to tell you.
James
'91 325i Sport
'93 318i touring 16v
ross2009
Post Sat Nov 30, 2013 7:36 pm
just use the longer gearbox bolts
Turbo M20
v8 project 6.0 twin turbo
Ivanhkde30
Post Tue Jan 21, 2014 7:15 pm
M12 1.75 x 60mm is what I used. 8)
jonny323i
Post Tue Jan 21, 2014 7:37 pm
Is it possible to mount it on a stand with the clutch still attached
Touring for life
ross2009
Post Tue Jan 21, 2014 7:39 pm
might be tight you can with the flywheel still attached but not sure on the clutch aswell
Turbo M20
