E30 M30 conversion Help
LadyLeigh
Tue Nov 12, 2013 9:41 pm
Started my conversion, engine is now in after purchasing the mounts from lee.
Tried to fire up this evening, it started. Went to restart it and nothing.
Doesn't seem to have a spark or fuel.
Running M30 engine Loom and ECU.
Any input would be great.
mcbonio
Tue Nov 12, 2013 9:54 pm
Is the ground strap on the engine connected?
jimbom30cab
Tech 1 freak
Tue Nov 12, 2013 9:57 pm
DME and fuel relays tight ?
Battery terminals done up tight ?
Tue Nov 12, 2013 9:59 pm
DME relay?
LadyLeigh
Tue Nov 12, 2013 10:02 pm
Ummmmm first conversion I have done, ground strap? Earth?
Jump pack was straight to engine?
LadyLeigh
Tue Nov 12, 2013 10:04 pm
Would anyone local enough to Reading be able to do it? If so at what cost? :cry:
Tue Nov 12, 2013 10:10 pm
LadyLeigh wrote:Would anyone local enough to Reading be able to do it? If so at what cost? :cry:
Hold on, deep breaths, and ..........................................relax. :D
Now, check fuses first.
Also, what engine was in the car before the swap?
LadyLeigh
Tue Nov 12, 2013 10:22 pm
M20 engine lol 325.
It's giving me a headache plus this stuff isn't my fav
Tue Nov 12, 2013 10:26 pm
Did you swap over the wires at the C101 plug?
jimbom30cab
Tech 1 freak
Tue Nov 12, 2013 10:28 pm
give me a call tomorrow during the day
07525 39111seven
leeparkes
Tue Nov 12, 2013 10:32 pm
Engine should still run without swapping the wires at the c101
If you have no spark or fuel try the white DME relay first, your M20 one will fit.
Earth strap is a thick wire that goes from the engine block and bolts to a chassis rail.
Rav335uk wrote:DME relay?
:wink:
Tue Nov 12, 2013 10:33 pm
Forgot to ask, you don't mention, is it cranking over?
leeparkes
Tue Nov 12, 2013 10:46 pm
:wink:
:flipbird: :)
Tue Nov 12, 2013 10:50 pm
:snigger:
jimbom30cab
Tech 1 freak
Tue Nov 12, 2013 11:00 pm
lovin' the M30 commardary
LadyLeigh
Wed Nov 13, 2013 8:34 am
leeparkes wrote:Engine should still run without swapping the wires at the c101
Where is the DME located?
It started up without changing over the wires on the C101.
LadyLeigh
Wed Nov 13, 2013 8:35 am
jimbom30cab wrote:give me a call tomorrow during the day
07525 39111seven
Thank you, will give you a bell today.
jimbom30cab
Tech 1 freak
Mon Nov 18, 2013 5:08 pm
have you got it running then? pleased with it mate?
bmwsean
Sun Jan 05, 2014 5:52 pm
funnily enough years ago I had the same problem when I did the m30 swap, after an hour of head scratching I took the engine loom of an replaced it with the original M20 one, fired straight up, must be something really simple
jimbom30cab
Tech 1 freak
Mon Jan 06, 2014 6:01 pm
Did the m20 engine loom fit ok ?
