I'm wanting to clean up a set of drive shafts for my rear subframe rebuild and was hoping to fit new CV joint boots but I was wondering if the BMW ones stretch over like all the ones on ebay or is there a correct way to fit them by disassembly?
Thanks Matt
How to replace CV joints
appletree
jimbom30cab
- Tech 1 freak
you need to strip them down to fit bmw boots, it's a pain in the ass job and new BMW boots are £65 a side!!
its much easier and much cheaper to buy a set of second hand drive shafts with intact boots
the bmw boots are much thicker than than the thin rubber cr@p on ebay which i would avoid using.
Never seen a split E30 boot yet! Not only are they as tough as the proverbial old boots, but they only get operated at very shallow CV joint angles, unlike the majority of boots in use that are on steering axles.
maxfield
I had a split boot on my E30.
Swapped it for a second hand driveshaft I had lying about.
If it ain't broke....
jimbom30cab
- Tech 1 freak
the best advice you can give regarding CV boot changes IMOIf it ain't broke....
Sanchez
- **BANNED**
Sanchez
She never noticed. SSSSHHHHH!!!
Was trying to warm the "stretchable" rubber but nothing worked.
appletree
top stuff well I have 4 good shafts at the minute but thought I would ask while its all in the workshop rather than attached to the car.
aimlessrock
i replaced mine only a few weeks ago and used proper dealer boots and cir clips. the best advice i can offer is to remove them from the car”¦the job is much easier and allows you the chance to clean out all the old grease etc.
E30 320i Convertible (1989)
190 Mercedes (1988)
190 Mercedes (1988)
