base power was 112Kw or 150Hp which is about right looking at other peoples results
We fitted a cheap ($800) stand alone ecu (called and EMU which by the way seems very good) and a set of our 40mm itb's, power went straight to 130Kw (174Hp) thats better than a lot of 2.7 strokers or engines with cams and other mods etc
To back up these results and make sure it wasnt some other irregularities we went to a different dyno and tested it again with the same result 129Kw
Note that it didnt loose any torque down low it gained everywhere from about 90Kph, the mixtures are rock solid running purely as Alpha-n (TPS load control), more stable than the motronic was.
so there you have it.... a good ITB is worth good power on ANY engine if its done right and you wont loose any torque or drivability
