Are e30 and e36 front suspension wishbones the same?
signous
Post Sat Nov 09, 2013 5:49 pm
I've sourced a decent price on a set of e36 Front Wishbones. The seller claims they are compatible but doesn't go into any detail.
Im running a 1990 e30 316i coupe and its failed MOT on front wishbone ball joints.
Are the e36 and e30 wishbones the same?
Cheers guys
Post Sat Nov 09, 2013 7:46 pm
E30 wishbones are used as an upgrade to E36s. Would be a downgrade fitting E36 ones to an E30.
Post Sat Nov 09, 2013 7:55 pm
£57 each for Lemforder from carparts4less with £15 off if you spend more than £100
Post Sat Nov 09, 2013 8:12 pm
capri_rob wrote:£57 each for Lemforder from carparts4less with £15 off if you spend more than £100
That's complete new arms, BTW, not just willnz's ball joints, which are considerably cheaper, but more work to fit.
