E28 M30 flywheel lightening
gareth
Post Sun Jan 08, 2006 1:28 am
is it worth lightening my E28 M535i single mass flywheel?
also, if i do, will it need rebalancing afterwards? (i assume it will)
gareth
Post Tue Jan 10, 2006 8:04 pm
anyone? :?
Andy335Touring
Post Tue Jan 10, 2006 8:34 pm
Not sure if its worth it ?
If you do it don't take too much metal off, i don't know how much is safe to take off before it becomes a problem ?
gareth
Post Tue Jan 10, 2006 9:04 pm
i'm thinking that due to the lack of prvious experiences on here, i'll probably leave well alone.
what flywheel have you got andy?
Andy335Touring
Post Tue Jan 10, 2006 9:31 pm
E28 535
gareth
Post Tue Jan 10, 2006 9:35 pm
cool
does it 'feel' like a lighter one would improve things?
Andy335Touring
Post Tue Jan 10, 2006 9:55 pm
TBH put the money into buying a decent chip as you will be better off.
I had a Superchip in before my Emerald, not sure if they still do them though ?
gareth
Post Tue Jan 10, 2006 10:10 pm
i'll just get it cleaned up then... it's functional but not pretty!
Image">
Templ8e30
Post Wed Jan 11, 2006 11:08 am
I've lightened a few flywheels over the years and most recently the flywheel for my 2.7 M20, I took 3kg off it. You will definately need to have it balanced afterwards if you do. Mine was quite a way out and has been tested to 8000rpm which it'll never get up to so it is still strong enough not to explode on me :eek:
Cheers,
Iain T
2007 Mazda 6 2.0 estate
Post Wed Jan 11, 2006 11:20 am
i'd say go for it.. helps take some weight off the front end albeit a tiny amount and rev up better
further toward the outside you remove the weight the more effect it has
gareth
Post Thu Jan 12, 2006 8:13 pm
cheers lads.
does anyone know a good place ito get it done? (ideally in sussex area)
