M30 AFM mod write-up or FAQ?
Rob_farmer
Post Sun Oct 27, 2013 4:24 pm
Guys,
I can`t find or there isn`t one on zone here? I`m willing to do the mod, but struggling to understand what injector plug & play options are available for M20B25? Americans use some 19 injectors from Ford I believe ?!
So far I`ve come to this: I need AFM +warm up and stretch rubber boot or get made one up +cone air filter +cold air box +ECU mapped for correct fuel flow +swap out M20 chip into M30 AFM +dyno before/after.
Just stuck with injectors :cry: :roll:
I`m driving E30, 1989, 325i, 4 door. Restoring 1990, 4 door.
jimbom30cab
Tech 1 freak
Post Sun Oct 27, 2013 4:37 pm
jimbom30cab
Tech 1 freak
Post Sun Oct 27, 2013 4:44 pm
Hong Kong fuey on here has done this.
I've Been in his car, it pulls very well, much faster than standard
I've read that an adjustable fuel pressure regulator is useful for this also
Rob_farmer
Post Sun Oct 27, 2013 4:46 pm
Thanks Jim. But if I get a list what injector options are available, I could source them myself not from US, then send off for refurbishment to tried and tested zoner. USA is just too far - long delivery, import duties/tax, in case of problems - costly postage back to US.
UK eBay has zero injectors listed by "19 Fuel Injectors BMW E30"
Rob_farmer
Post Sun Oct 27, 2013 4:47 pm
jimbom30cab wrote:Hong Kong fuey on here has done this
What`s his correct username?
reggid
Post Mon Oct 28, 2013 6:52 am
dont waste your time with the M30 AFM unless you will get it custom tuned afterwards to run properly.
E30 325is with M20B31
Rob_farmer
Post Mon Oct 28, 2013 6:54 am
reggid wrote:dont waste your time with the M30 AFM unless you will get it custom tuned afterwards to run properly.
I will get it done, that`s no problem and cheap.
Quaser
Post Mon Oct 28, 2013 9:09 am
speak to dmcl - he has done this and also sells the chips for it too
Rob_farmer
Post Mon Oct 28, 2013 9:34 am
I`m stupid - how on earth I can find him? Member`s list doesn`t have search function ?!
Quaser
Post Mon Oct 28, 2013 10:22 am
that's a post he did, just pm him from there
