Coolant Coming Out Overflow Pipe????
Nobby_N
Since doing the Crank sensor the 320 has decided to use alot of water/coolent! Cant see any leaks and no mayo under cap. Give me a clue people to what i can look for next, cant see that ive knocked any thing fitting CPS, cap fits nice and tight but after a run it does seen to be a little looser??? Car runs fine and does not overheat!
Check the elbow that comes off the thermostat housing, they are usually pretty corroded and weak by now and are easily broken when rummaging around that area , which you will have been when removing / replacing the sensor. The fix involves a replacement housing , I have them in stock and mine are strong !
Have you started decontenting the sorry turd yet ? ready for its inevitable demise
Nobby_N
I filled the fooker up while its running and temperature will not go above have and not using any water, it seems to be when its driving along it losing it but soon as its stationary its fine and just cant see where its going, runs good but it maybe Ebay bound lol what do these rare quattroporte go for lol trouble is I do like it and think I may put some money into it.
Nobby_N
Right It seems when I rev it the water is coming out the overflow pipe that runs down too passenger side wheel, why is it doing this???
Grrrmachine
- E30 Zone Wiki / Team Member
Because you overfilled it?
gooner1
- Out humping Reindeer
Grrrmachine wrote:Because you overfilled it?
Nobby_N
No it emptied its self hence why I filled the fecker, why would coolent light keep coming on if it does not need it!!
Nobby_N
It empties the whole lot btw making the light come on
Nobby_N
Head gasket maybe?
hennared323i
Airlock? or thermostat failure?
You have pm btw
You have pm btw
Nobby_N
I did try bleeding the system before the darkness came! Roll on the weekend, wish I was a bit more mechanically minded so I could bang a 2.5 in it as its pretty solid but never going to be a minter
Nobby_N
Well ive driven to work this morning, 10 miles through traffic and decent roads, ive just been to have a look and the cap was resting on front of the tank, cant see it would have blown off so maybe i left it off! Either way it has used no water and level is spot on??? what the feck is going on????
- **BANNED**
With the cap on,the system is pressurising.
Air is entering the system and blowing the coolant out.
Have you taken Pacerpete's advice,yet?
Youth is wasted on the young.
Nobby_N
Ive not had chance, If it was the housing then i would see water coming out would i not?daimlerman wrote:With the cap on,the system is pressurising.
- **BANNED**
Water is very sneaky stuff,it finds the easiest route out,in your case via the overflow pipe.Nobby_N wrote:Ive not had chance, If it was the housing then i would see water coming out would i not?daimlerman wrote:With the cap on,the system is pressurising.
What you need to discover is why the bloody stuff is making a bid for freedom.
Pacer's post makes perfect sense to me,air is entering the system via a corroded alloy component and forcing water out via the overflow,aided and abetted by the water pump.
Obviously,both Pete and I are talking complete bollocks,in your usual style!
Nobby_N
??? how very rude, im not a mechanical hero like you Mr foooking Dulux and i do listen to Pete! I was saying that surely if the corroded housing Pete mentioned was the problem then surely i would see water, I will strip it down and have a look over weekend!
- **BANNED**
Any smoke from the chimney?
Nobby_N
Sorted now, I bled the system and got any air out and shes now not using coolent and running a treat! God knows how air got in the system as all I did was swap the CPS over but hey ho its running great!
sweep
No console for me then
Nobby_N
Lol
- **BANNED**
Nobby_N
Why would I need to bleed the system after a simple CPS replacement????
sweep
it was a under lieing issue by the sounds of it? did the previous owner smoke ronnies?
Nobby_N
It ran fine for 2 weeks then the cps foooked up and started using water so fooook knows, running or not it stands me at 400 quid so Im surely getting that back when she hits ebay lol
sweep
did it have water in the header tank or anti freeze?
Nobby_N
Coolent of some sort!
sweep
The previous owner was eager wasnt he....
spook
- League two here we come !!!
Did you drain the coolant and replenish like a good zoner Nobby?
Nobby_N
Did I foooooook! Its an old banger and never ganna be anything but, it will hopefully run till the mot runs out then be turned into a fridge!
Nobby_N
