Z3 Steering Rack Conversion... How much?
- Rob_farmer
worth 300-350, I paid 305
I`m driving E30, 1989, 325i, 4 door. Restoring 1990, 4 door.
What was included in that cost.Rob_farmer wrote:worth 300-350, I paid 305
I went for the E46 067 rack, along with Danthe custom pipes, spacers and linkage, plus the cost of E34 UJ's and burton engine mounts and I think it was around the £300 mark.
This is what I thought and that the z3 rack was just a hyped up expense.Andyboy wrote:The E46 rack is just as good as the Z3 one, and they're 40 quid - plus the cost of Dan's conversion bits.
My old rack was foooked.
- Rob_farmer
2.7 turn to lock ratio?Andyboy wrote:The E46 rack is just as good as the Z3 one.
- Rob_farmer
E46 is not as good as Z3 rack:
Car-----------mm/ per. turn--------BMW Part #
E30------------36.5 mm------------32 13 1 092 335
E30 M3---------38 mm--------------32 13 2 225 556
E36 M3 '95------39 mm--------------32 13 2 227 191
E36-------------45.5 mm------------32 13 1 096 280
E36 M3 96+------45.5 mm-----------32 13 1 096 280
E36 Z3 M---------45.5 mm-----------32 13 1 096 280
E46 Std-----------50 mm------------32 13 6 755 065
E85 Z4 M----------51 mm------------32 13 7 836 844
E36 Z3 non-M------53.5 mm----------32 13 1 095 575
All about racks:
http://www.r3vlimited.com/board/showthread.php?t=66247
http://www.rmeuropean.com/bmw-e30-steering.aspx
http://www.r3vlimited.com/board/showpos ... stcount=64
http://www.e30tech.com/forum/showthread.php?t=115686
http://www.r3vlimited.com/board/showthread.php?t=172261
All about racks:
That's the E36 M3 rack which has bump stops which restrict the lock.
Z3 rack is has a quicker ratio than the E46 rack. Z3 racks are also harder to get hold off, it's the 1.9 rack that fits.
- Rob_farmer
They don`t cost £30. There is quite demand for them for a reason. Also mine came off car with just 60k on the clock.pacerpete wrote:£300 spent replacing foooked bits is arguably a better investment !
Rob_farmer wrote:They don`t cost £30. There is quite demand for them for a reason. Also mine came off car with just 60k on the clock.pacerpete wrote:£300 spent replacing foooked bits is arguably a better investment !
My point being MOST E30s would benefit more from £300 being spent on replacing the myriad of foooked parts that MOST of these cars are afflicted with than fitting a quicker rack that the cool kids told them they must have.
That's the standard e46 rack though, the 067 is quicker than the normal one taking it pretty close to the z3 rack.Rob_farmer wrote:E46 is not as good as Z3 rack:
All about racks:
However, 067 racks are about £40, z3 1.9 racks regularly go for five times that much, and the cars they come off will be older.
Either way, both are a vast improvement over the standard e30 rack!
Immy, the table shows rack ratio, how far the rack mover per turn of the wheel, and is a measure of how 'quick' the rack is, and the best way of comparing different racks. As you can see, the standard e36 rack had exactly the same ratio as the m3 evo one. No coincidence because they're exactly the same, but as you say, the evo rack has less overall lock so looking at the turns lock to lock figure alone you would think the evo rack was quicker.
And people still try and charge a premium for evo racks!
The e36 3.0 rack is misleading because its variable ratio, so its very slow around straight ahead, but quicker at the ends, so it has less turns lock to lock than other e36 racks but they're horrible and were a major source of complaints when the e36 m3 was released. One to avoid at all costs!
cheers,
harry
harry
- Rob_farmer
How much more complicated fitting E46 rack is compared to Z3 one ? Any articles on it?
Fitting is the same for all E36/E46/Z3 racks.
- Contact:
My chromie feels fine with the needle off the clocks, that is a standard 3.4 turn E46 rackajay wrote:+1 As Dan says, but above 120mph they are both quite frightening, way too sensitive for my likening!
The 067 on my sport is exactly 3 turns lock to lock, (feels great most of the time) but i realised the weekend just gone,while chasing a carrera S that its a bit too sensitive when manovering at high speed. Maybe its just me needing to get used to it!
Grrrmachine
- E30 Zone Wiki / Team Member
I just bought a standard E46 rack for my LHD chariot, and the part number shows it also fits E36s, so no idea how much turn it'll have.
The conversion is quite straight forward, just nuts a bolts mainly. The only slight fiddly bit I found was mating the different UJ's together.. but read through this.. all is explained in here..Rob_farmer wrote:How much more complicated fitting E46 rack is compared to Z3 one ? Any articles on it?
http://www.e30zone.net/modules.php?name ... c&t=148445
Everything else is found in the wiki pages and a quick search on here under 'steering rack conversion'.
Demlotcrew
Geo needs tweakinga little And!ajay wrote:The 067 on my sport is exactly 3 turns lock to lock, (feels great most of the time) but i realised the weekend just gone,while chasing a carrera S that its a bit too sensitive when manovering at high speed. Maybe its just me needing to get used to it!
jimmyspeed
you can get cheap z3 racks if you hit it lucky on ebay i got mine for 30 quid - i have yet to drive the car so cant comment on how twitchy it is
one advantage is you can install it with the original steering linkage
Demlotcrew
The E46 rack is much better valved than the Z3 1.9, however if you don't care about feedback and only want a quick rack for fast input when drifting/rally etc then the Z3 rack is for you.
Andrew
Andrew
