my attempt at e30 with m62 v8
LongR
Post Thu Sep 12, 2013 8:10 pm
so after i bought the 5 series with m62b44 and i didnt like it and had no luck with it and crashed it i decided to make some use of the engine and gearbox.
the car maybe had some mileage on it 162k but the engine sounded sweet and manual 6 speed gearbox was good aswell..
after not realy long time thinking if i should go for e36 or e30 i started looking for a car.
on here i found one with cage (not the best one in the world) ,fiberglass body kit some brakes and sporty suspension for a good price so decided to buy it.
few days later i had the car int the garage and started putting it apart to find out that some of the beautifull rust was covered with filler. actually quite a bit of it.. however just on the back.
pushed it inside
took the engine out of the 5 series
and as much as i didnt like the view of it.. needed to get rid of the 5 series shell
cheked the bottom end for loose bolts as i eard they may come loose
and started the worst job ever.... wiring
removing unnecesary bits
once tons and tons of cables were no longer required we started taking everything out from inside and engine bay.
so shitty dashboar butchered by previous owner. burned engine and old wiring loom
after giving a bit of a clean to the engine bay i thought it will look better in white and rust proofed at the same time
before
and after
after that.. removed everything from inside and after cleaning rust proofed that aswell
and bit of assembly of wiring in the car
unfortunately when i started taking it all apat i founf lots of rust at the rear end so had to sort it out.
(im not the best at it)
started the angle grinder and cut shit load of it out
but in the end.. bit of welding and fiberglass filler made it more like a car that a shit bucket
ok.. so after fixing some of the rust problems it was turn for the engine
it was actually easyer than i thought to put it there.... there is not much space in certain places but all in all good.
done bit more of wiring
and to my surprise it actually worked.
after that i tried to start it.. and i did.. without manifold.. and jesus was it loud.
anybody who looked into the m60/m62 engine conversion in e30 should know that the manifolds are a bich to do with shit clearance.
i gave it a go anyway... knowing that over the winter i will be doing it properly i just made some steel ones to get the idea what goes where.
with all that done it was finally time to put some seats in .steering wheel.. hydro and sort of set it up for my height so its comfortable.. im nearly 7 foot tall.
with this done and a little tidy up i had to somehow put some colour on it as the black red paint was shit and annoing.
and after a small coat of primer or should i say something to rub down before painting over winter
right now im doing some mods to lock and other small bits.
so should be out on the track soon.
321gazza
Post Thu Sep 12, 2013 8:32 pm
Very nice work their mate looking forward to more progress.
321gazza
Post Thu Sep 12, 2013 8:33 pm
LongR
it still needs lots of work.. its going to be a busy winter i guess
m62 powered e30 in progress
LongR
Post Thu Sep 12, 2013 8:37 pm
its only been my first attempt at few things like manifolds and such so i think it went well enough
suchy
True Zone Relic
Post Thu Sep 12, 2013 8:39 pm
Yeah just pull this bit out and throw that bit back in- and it started, job done!!! 8O
You make it sound so easy :)
Post Thu Sep 12, 2013 8:41 pm
Looks good so far :)
5 series clocks too :cool:
LongR
Post Thu Sep 12, 2013 8:48 pm
it wasnt as easy.. but on the other hand.. wasnt that tricky either..
took me and a mate two months to do it, but that was just weekends and some evenings.
and beiing polish lots of alkohol later and its done.
turn the key.. and it lives
yeah.. manifolds took me a while... but now over the winter i will have those at templates and tig weld the new ones properly.
as for the clocks from 5 series.. its a must.. m62 and all ews stuff...
unfortunately with the way cage was build before for the old owner the closc had to be smaller that that so had to take all the plastics from around it and make it thinner.
will upload some photos soon.
one way or another the cage will be going out and new one and dashboard in over the winter.
turk
Post Thu Sep 12, 2013 8:58 pm
looking great!!! More e30V8's ftw winkeye
btw we do a bolt on stainess manifold kit for the e30 v8. Take a look on the fb page.
https://www.facebook.com/media/set/?set ... 927&type=3
keep the pics coming :D
cheers
Adem
S54, S62, S65 & S85 Plug & Play loom/Ecu Kits
Sump Baffles
Engine Conversion Kits/Parts
TrackDays
LongR
Post Thu Sep 12, 2013 9:02 pm
as much is i like buying things i enjoy learning more..
plus it will give me much more satisfaction in doing the manifolds myself.
Nobby_N
Post Thu Sep 12, 2013 9:08 pm
Good thread this :D
LongR
Post Mon Sep 16, 2013 5:17 pm
so i had a little play over the weekend and did few things.
first it was a mess with lots of switches around so decided to cut a little plate to put all those in order.
so windows lights fuel pump and ignition barel from 5 series aswell as place for heater controls and so on.
then i cut some spacers for the steering improvments
some of them not 100 finished.
as well as modified cluster as the front cover was annoing and odd looking
it does look a bit buchered but will do for now.
maybe some fancy looking display soon when i get rid of EWS
jimbom30cab
Tech 1 freak
Post Wed Sep 18, 2013 9:20 pm
turk
Post Wed Sep 18, 2013 9:52 pm
I bought a set of these off the same people and they didnt fit. In fact they still owe me a refund from 18 months ago. We gave up and now make our own instead.
Sump Baffles
TrackDays
jimbom30cab
Tech 1 freak
Post Fri Sep 20, 2013 1:44 pm
Thanks for the intel, well worth knowing
Phill172
Post Mon Oct 14, 2013 10:52 am
two e30 v8s in the same town!
coming along nicely, whats your plans for the lock mods, ill trade you some if you fix my rust!!!
tomislav
Post Mon Oct 14, 2013 11:04 am
ooh, watching with interest!
LongR
Post Mon Oct 14, 2013 11:09 am
ha.. im in the cnc and computer aided design business. still not great at it but i have a project over the winter.
basically i want to design and do new extended arms with a trackrod relocation plate.
so bare with me.. should have aswers begin of next year.. just looking through materials right now and possible designs.
i was going to contact you Phil as i wanted to ask few questions about v8 when i was doing mine but somehow i lost track of time and life around me apart from car.
GB69
Post Mon Oct 14, 2013 11:35 am
I couldn't be bothered messing about with lock mods, so went for the wisefab kit.
I got sick of replacing e46 wishbones on my e36, and tie rods.
LongR
Post Mon Oct 14, 2013 11:39 am
Its more of a project if i can do it..
Too easy to just buy it
LongR
Post Wed Oct 16, 2013 8:43 pm
so not much happened to my car recently...
changed front hubs to e36 and fitted e36 coilovers on the fron..
still have to decide if i should book some track time before christmas as weather is going to be shit
